.xml problem
  • jvob
    • 4
    .xml problem
    hi guys.having problems.Thanks so far guys. Just so its clear here's what i've done:
    1 flashed with nabilosat - all known transponders have been tried error message.
    2 downloaded a satellites.xml file and put it into var/etc - got same error message
    3 flashed with pli jade 3 - no lock or sync again
    4 copied all files off my working box and put them on non working box when it had nabilosat --- same error again
    5 tried erasing 3 times then reflshing - no luck
    thanks in advance for any extra help
    also,would my warranty be ok after ive flashed box,if i need to send it back.thanks
    This message has been edited since its posting. Latest edit was made on 11 Oct 2010 @ 8:35
  • halim2731
    • 9
    Do try to flash back your box using dreamup and using cable modem, do not use Flashwizard.
