Can't get newcs working with cccam ??
  • gold7
    • Oct 2010
    • 7
    Hi everyone .
    this is my log in newcs , if any one can help me to get cccam working with newcs i would be very greatful .
    I have newcs and mgcamd running fine on my dm 500 (gemini) , how ever I can't seem to get cccam to work with newcs.
    Let me point out i have to use newcs cos I have a tring tv card which is conax encrypted do newcs is needed for the card can be read by the receiver.
    My log is below from newcs . My question is what do I need to add to this log to get cccam to work ? I've been trying all day for hors following some 2 year old guides but can't get it to work thanks .
    Thanks for any help.
    <newCSconfig>
    <readers name="SCI">
    <device>
    <name>Lower Cardreader</name>
    <type>sci</type>
    <mhz>357</mhz>
    <node>/dev/sci0</node>
    <parity>odd</parity>
    <reset>normal</reset>
    <export>Yes</export>
    <enabled>Yes</enabled>
    <blocksa>No</blocksa>
    <blockua>No</blockua>
    <blockga>No</blockga>
    <irdeto-camkey>0000000000000000</irdeto-camkey>
    <irdeto-camkey-data>0000000000000000000000000000 00000000000000000 000000000000000000000000000000000 00000000000000000 000000000000000000000000000000000 00000000000000000 000000000000000000000000000000000 00000000000000000 000000000000000000000000000000000 00000000000000000 00000000000</irdeto-camkey-data>
    <crypto-special>No</crypto-special>
    <ipk>0000000000000000000000000000 00000000000000000 000000000000000000000000000000000 00000000000000000 000000000000000000000000000000000 00000000000000000 000000000000000000000000000000000 00000000000000000 000000000000000000000000000000000 00000000000000000 00000000000</ipk>
    <ucpk>000000000000000000000000000 00000000000000000 000000000000000000000000000000000 00000000000000000 000000000000000000000000000000000 00000000000000000 000000000000000000000000000000000 00000000000000000 000000000000000000000000000000000 00000000000000000 000000000000</ucpk>
    <PTShandshake>No</PTShandshake>
    <carddetect>yes</carddetect>
    <newcamd_port>34000</newcamd_port>
    <autosid>Yes</autosid>
    <Seca-PPV>no</Seca-PPV>
    <pincode>1234</pincode>
    <priority>round</priority>
    </device>
    </readers>
    <cache>
    <emm>20</emm>
    <ecm>-1</ecm>
    </cache>
    <debug>
    <password>NewCSpwd</password>
    <level>normal</level>
    <type>init</type>
    <output>console,tcp</output>
    <console_options>normal,init</console_options>
    <tcp_port>1001</tcp_port>
    <tcp_options>normal,init</tcp_options>
    </debug>
    <newcamdserver>
    <name>newcs</name>
    <server-ip>myname.dyndns.org</server-ip>
    <deskey>01 02 03 04 05 06 07 08 09 10 11 12 13 14</deskey>
    <user><name>my username</name><password>mypassword</password><hostname>192.168.1.**</hostname><port>34000</port><au>yes</au><spider>no</spider><sidoverride>yes</sidoverride><rate>2</rate></user></newcamdserver>
    <httpd>
    <server>
    <port>8080</port>
    <enabled>yes</enabled>
    </server>
    <user>
    <name>newcs</name>
    <password>newcs</password>
    <accesslevel>admin</accesslevel>
    </user>
    </httpd>
    </newCSconfig>
    <user>
  • thewizardofodds
    • 924
    no card sharing talk allowed on here
    • gold7
      • Oct 2010
      • 7
      Sorry . Won't happen again .
      • firestorm
        • 1550
        down load Cccam 2.12+Newcs1.65 and to be honest its not card sharing it using a emulator to read a ligament card owned by gold7 at no piont is sharing it mentioned. if we cant talk about this we may as well remove everything in sat section apart from dish aligning
        You then need to add password and user and then add the appropriate line in your Cccam.cfg file
