DM500 - 3 Day UK EPG Without Network Mount With PLI ImagesIt is possible to have 3 da
  • pogo2009
    • 45
    It is possible to have 3 days UK epg on a DM500 without network mount by storing the data in tmp. Many people including myself believed there simply wasnt enough free space but i have tested this and it is working 100% and performance is not affected in any way, infact it works better than a mounted epg file.Below i will explain with screenshots how to do it.
    First you need to select tmp as the storage area, using the remote menu go to system settings.
    Select EPG
    Select SQLite as epg data store, you will see a warning ( THIS DIRECTORY HAS NOT GOT ENOUGH SPACE ) just ignore it.
    And browse to tmp for location then press green to select.
    Now exit the settings menu and press yellow to bring up the plugins menu, select Dreambox EPG Config.
  • pogo2009
    • 45
    DM500 - 3 Day UK EPG Without Network Mount With PLI Images - part 2
    Select the following as in the picture,
    Package - Radio Times UK
    Time Offset - 0 Hours
    Number Of Days - 3
    Now press blue and you will see the channel mapping screen, here you just need to match the channels from your bouquet in the left and right boxes, this is a pain but only has to be done once.When done press green to save.
    You will now be back at the EPG config screen, press yellow and you will see the epg data being retrieved.This takes 10-15 mins but once done you will now have full working 3 day epg without the need for a mounted drive.
    The only downside to storing the data in /tmp is when the box is rebooted all data is deleted, how ever this can be overcome if you ftp into your box and find the tmp folder.
    Look for the EPG.DB file and copy it so should you have to reboot then you only need to ftp the file back into /tmp.
    Before trying to update the guide via Radiotimes check this link HERE if you see a single line like this "In accessing this XML feed, you agree that you will only access its contents for your own personal and non-commercial use and" then it is off line and dont bother. If it is online you will see a full epg database page and then you can retrieve it via your DM500.
    • the man
      • 1660
      thank you ............
      • dctyper
        • 2539
        why dont you just go to the hip hop channel in the radio and let it update the epg, set the timer to go to the channel every day, nice and easy
        dc
        • rogerduke
          • Oct 2010
          • 17
          Hi Dc, ive been trying to find the hip hop radio station but cant see it listed on the radio, any idea where it is?
          • the man
            • 1660
            if a mod deleted my post can you tell me why pleases?
            • satsmo
              • 6397
              It wasnt me but you already asked via the report button, so no need to ask on the thread.
              If it was deleted there is usually a good reason for it. However are you sure you are not mixing this thread up with the other part of the continuation of this thread?
              Is this the missing post http://www.digital-kaos.co.uk/forums...rt-2-a-169982/
              • satsmo
                • 6397
                This thread and part 2 of it are copied and pasted from elsewhere and are specific to an unmounted /tmp epg.db using PLi for a DM500s.
                • dctyper
                  • 2539
                  Astra 2A (28.2E) - 11778.00 V - Txp: 4 - Beam: Astra 2A North DVB-S (QPSK) - 27500 2/3 (ASTRA
                  might not be called hip hop anymore bet deffo carries epg, check king of sat
                  dc
                  • the man
                    • 1660
                    my mistake , thanks satsmo , sorry op
                    good work but i cant get it working maby some clones are not good
                    • satsmo
                      • 6397
                      dc
                      This thread as said is specific to E1 DM500 epg. EPG grabbed via hip hop is specific Nabilosat Black Hole images for DM7025, DM800 and DM8000 which are Enigma 2.
                      rodgerduke has a DM500s.
                      • satsmo
                        • 6397
                        No problem. It definitely works with PLi once the radiotimes xml is up and at the moment it is. What image are you using and have you mapped the channels you require EPG for?
                        • the man
                          • 1660
                          now on darkstar but iv try it on pli 4/5 times will try with a differnt 500s then the ones i tryed before.
                          it may had been the xlm was down when i try it , will update once iv re tryed, thanks
                          • satsmo
                            • 6397
                            You can check the xml here http://xmltv.radiotimes.com/xmltv/112.dat as you will see it is fully populated now. Try it will PLi Jade or Open PLi
                            I have tried with both and find Jade although older to be fine once channels are mapped correctly.
                            • pogo2009
                              • 45
                              dc
                              Does not work on a dm500.
