Flashing a dm500
  • adeobolo
    • Apr 2010
    • 13
    Flashing a dm500
    Hi guys, I just used flashwizardpro to flash my dreambox500 using flashwizard pro. I flashed digital kaos' new image and was wondering how do install ccam on it? I know on darkstar images it was yellow button---> etc.
    How do you install ccam on this image?
  • mario123
    • 383
    i cant remember with this image. if u just fiddle around with the new image u usaully find it after a while
    • opsmonkey
      • 5379
      the digital kaos image was designed for use mainly on the cable variant of the Dreambox..
      If you are on Satellite go for Gemini 4.2 or PLi
      • celticnthell
        • 52
        Use the pli image and set-up the sat config and save. Then you will see an option to download the latest menus do this and a new look menu will appear and cccam config and bin files are all there mate be sure to download both files or cccam won't work m8. Enjoy
        • damionhinds
          • Oct 2010
          Hi guys i am new to this i would like to know how to setup bouquest the problem is i dont even no how to upload it to the box an setup can some 1 help me plz!
          • celticnthell
            • 52
            What sat's are you looking to install the bouquets for? If its 28.2 there is updated bouquets in the downloads section.You can use dreambox edit to transfer the data from ur pc to the dreambox via your router if your using a dm500 just remember to use the type 2 settings before sending the data across.if its other sats or multiple sats there is also bouquets in the downloads m8
            • adeobolo
              • Apr 2010
              • 13
              What do you guys mean use a PLI image, your saying to use a diff version of the image I downloaded [ PLI ] version, and then it will load ccam?
              • celticnthell
                • 52
                Yes download the pli image from pli.org then follow the steps from my post above m8.dont forget to get both parts of the cccam config and bin.
