movies premier problems
  • bigoz
    • 105
    got a 500s which is completely glitch free for all subscription channels, but movies premier and premier +1 are unwatchable due to pixelation and break up of picture - any ideas why only these two channels would give issues when all others are completely glitch free?
  • Wingnut
    • 376
    mate just double check as i heard there frequency changed,try new scan,hope im right
    • the man
      • 1660
      spot on there was thriller aswell
      • billy2
        • 1381
        you can get updated bouquets from here m8
        • bigoz
          • 105
          http://www.digital-kaos.co.uk/forums...ularly-163750/
          thats the one im using, for some reason these channels have never worked on my box - SNR is very low but only on thes two channels, all others are perfect.
          • pogo2009
            • 45
            tps for movies prem & 1 have changed, just scan this in 11836 H 27500
            • bigoz
              • 105
              no channels found at that frequency
              • father ted
                • Feb 2008
                • 1389
                [QUOTE=bigoz;836679]no channels found at that frequency[/QUOTE
                just carry out a manual scan m8 mind and save your bouquets and servcie file before you do it DONT OVER WRITE them
                • bigoz
                  • 105
                  [quote=father ted;836716]
                  just carry out a manual scan ...
                  i have, but its not finding those two channels at the frequencies everyone is suggesting.
                  • plasterer
                    • 1631
                    A rescan will pick them up
                    Did for me ,then just move them back to your movies bow k
                    Sky prem and sky thriller ,Back up and running
                    But prem +1 showing sky movies temp fault
                    Hope this helps .............Paul
                    If your Happy with the Help push the Thanx button
                    PAUL
                    • gsmtech
                      • 264
                      you might have a dish alignment issue o LNB issue, meanng your unable to get a good signal on the new frequencies.
                      • smithie46
                        • Aug 2009
                        • 72
                        new freq 11836 sr.27500 H. SKY PREM+1
                        • bigoz
                          • 105
                          tried that - no channels found
                          • Unclephester
                            • Oct 2010
                            • 5
                            I am haveing the same problem
                            I think it must be a software glitch
                            Went to the sat shop for him to try but no success
                            So Iam takeing it to where I got it from
                            Let you all know how I've got on
                            • opsmonkey
                              • 5379
                              have you tried a manual scan of the transponder..??
                              I've seen a few instances of this in the last few days..
                              Wonder if you are all on the same image..??
                              Try updating your satellites.xml file and rescan..
