Does DM500 need to be connected to the internet at all times?
This topic is closed.
  • seanmckeown
    • 206
    if using a c-line with cccam, to watch ur dreambox does it always have to be hooked up to the internet?
    my internet box is in a different room to were my dreambox and tv will be.
    any ideas?
  • dctyper
    • 2539
    if its not connected you will only get fta channels
    • seanmckeown
      • 206
      have you had any experience using a wifi bridge?
      • opsmonkey
        • 5379
        wifi bridges are excellent..
        how far apart are the items..?
        can you not run a 10m Ethernet cable through a gap in the wall..??
        • seanmckeown
          • 206
          i probably could but it would be a bit untidy.
          my tv and box would be in the upstairs bedroom and my internet box in the downstairs living room.
          would you recommend the wifi bridge for the problem that I have?
          • opsmonkey
            • 5379
            a Wi-Fi bridge is the only way to solve your problem really..
            • seanmckeown
              • 206
              cheers thank you.
              on another topic if you dont mind.
              is it ok to use sky broadband to function the dreambox or would sky catch on?
              • the man
                • 1660
                homplugs work way better than wifi for me.
                  from what i hear these are the way to go solwise.co.uk sell them
                  • the man
                    • 1660
                    yer i got the cheper ones ?35 a pair 85meg one work g8 ,
                    my wifi keeped going a bit nutts
                    • seanmckeown
                      • 206
                      could you please explain how the homeplug would work for the dreambox?
                      sorry but I just havent heard of them before so dont know anything about them
                      • Mjolinor
                        V.I.P. VIC
                        • 1093
                        They provide a transparent extension of the Ethernet over the wiring in your house. Ethernet Dreambox to homeplug, Ethernet other homeplug to router and it will connect the Dreambox to the Router.
                        They can be a bit fiddly sometimes as it does not always work in every socket but once set up they will be reliable.
                        • wilf
                          • 1618
                          get a pair of homeplugs. you plug one in next to your router and put an ethernet cable between the 2 then plug one in next to the dreambox and connect the 2 with another ethernet cable and then you have a wireless network they are excellent
                          • opsmonkey
                            • 5379
                            i wouldn't share a sky card over sky broadband...
                            • bob114
                              • 192
                              hi
                              if you are sharing a s#y card around your own house
                              you don't need to be connected to the internet
                              and homeplugs work great
