2 DM's, 2 rooms, best control option?
  • norry
    • Nov 2010
    • 12
    I realise this will have been asked before (what hasn't?) so am just looking for a quick answer, a line or two, if someone can help me.
    I'm new to dreamboxes and ordered a DM500S to test the water, but before it even came I decided I wanted HD capability so ordered a DM800 as well. I am in the process of setting both up, getting there.
    Anyway, my plan is to have one in the living room, DM800, and one in the bedroom. I have a satellite feed only to the living room and don't want to run another cable if I can help it. Both boxes will be ethernet'ed up.
    I have UHF piped throughout house and see you can get SCART to UHF modulators, so one plan I had was to do away with the 500S, and use a smartphone for remote control over wifi but I'm sure there must be a better solution out there using the second box.
    Is it possible to change channel on the main box by sending a signal from the client in my bedroom via ethernet?
  • Curious123
    • 2591
    You could connect to your box through the web and change the channel.
    • dctyper
      • 2539
      smartfone is the best option
      • norry
        • Nov 2010
        • 12
        Thanks, thought smartphone would be the way to go, means the second DM box is wasted, unless at some point I run a cable.
        Time to buy a Scart to UHF modulator then.
