Cannot mount PC drive using gp image
  • Tal1481
    • Jun 2009
    • 18
    Hi guys,
    I've mounted many a dm500 - was very easy.
    Just upgraded to a dm800 and want to mount a shared folder (shared with everyone) called dreambox to my dm800 (this folder mounts fine on a dm500) off 1 of my pc's.
    I have a windows platform so I am using CIFS, I've tried everything I can think of but all I get when I press record is an error saying "hdd less than 100mb". I check the mounts and it tells me the mount is active on the right hand side (indicated by a big green tick) but on the left it tells me the drive isn't mounted (indicated by a red cross). I've searched for the last 2 hours but all I come up against is a nabilo guide - but I have a gp 4.4 image as my box is a clone.
    Any help greatly appreciated.
  • opsmonkey
    • 5379
    Have you tried to mount the hdd via DCC..?
    • Tal1481
      • Jun 2009
      • 18
      Dcc? Not sure what u mean bud
      • Tal1481
        • Jun 2009
        • 18
        Ohh, Dreambox control centre - will try that now mate - thanks
        • Tal1481
          • Jun 2009
          • 18
          I'm not sure how to mount a drive using dcc - only the nfs option is available?
          • opsmonkey
            • 5379
            sorry bud.. are you trying to mount a HDD in your box or a network drive..??
            • opsmonkey
              • 5379
              Have a read of this..
              • Tal1481
                • Jun 2009
                • 18
                A network drive mate - it's located in 1 of my pcs on my home network.
                • Tal1481
                  • Jun 2009
                  • 18
                  I just want to record from dm800 to my pc bud
                  • Tal1481
                    • Jun 2009
                    • 18
                    Also - I don't have the options over the web interface that the user guide u pointed me 2 has.
                    • opsmonkey
                      • 5379
                      Try this..
                      Automount CIFS on DM800:
                      Blue-Panel
                      Extras/Settings
                      Automount Editor
                      Add (green buton)
                      Mountpoint: Directory
                      Type: cifs
                      Options: rw,soft,udp,nolock
                      Username: user (example: db)
                      Password: pass (example: dreambox)
                      Bufer Size: rsize=8192,wsize=8192
                      server: ip of your pc (example: 192.168.1.123)
                      Share: folder that you want to share on PC (example: /FUN)
                      In this way you will automount folder "Fun" from your PC (192.168.1.123/fun)
                      To access this folder on DM800, go to:
                      menu
                      Media Player
                      Directory (automount) in "filelist"
                      You must use active user and pass on device that you connect to !
                      • Tal1481
                        • Jun 2009
                        • 18
                        Ok, I can now browse that directory in media player but it still will not let me record what I'm watching on my dm800 to my hard drive by pressing the red button.
                        Any ideas?
                        • opsmonkey
                          • 5379
                          reboot the box
                          • Tal1481
                            • Jun 2009
                            • 18
                            Still no joy.
                            There seems to be setting in a few places - I've tried using automountmanager supplied with the image but all I get is "hdd < 100mb" when I press the red button.
                            Thanks for all your help thus far bud - it's really appreciated.
                            As well as the mount manager there is also a setting called recording paths.
                            The options for mountmanager are:
                            local share name:
                            mount type (I've et this to cifs)
                            server ip: (I know to put the host pc ip here)
                            server share:
                            use as HDD replacement:
                            mount options:
                            Username and apssword (I've set these to my pc uname and pword)
                            • opsmonkey
                              • 5379
                              In Gemini 4.5 you can change the recording path by..
                              Go to Menu -> settings -> system -> recording path and set it up according to what your location is
                              don't think you can change the path in 4.4
