Fan
  • waj_uk
    • 175
    Fan
    Hi, Ive had my Dm800 (clone) for just over two weeks now and it has been running fine with no problems.
    This morning when i came to switch it on, and it started making a loud whirring noise as if it was about to take off!
    I'm guessing this is the fan/cooler?
    Should i be worried or can i leave it? and how will it affect the running of my Dm800?
    The box does seem quiet now after a while of leaving it on, i just though it was a bit odd as i havent heard anything since i bought it until this morning
  • andy91
    • 3583
    Disconnect it and buy one of them cheap fans for it to stand on.
    Andy.
    • plasterer
      • 1631
      Fans
      Just whip the lid off mate and pull the connector off
      Its up to you if you want to add another underneath
      or above it ,you can pick them up for about 3 quid ....Paul
      If your Happy with the Help push the Thanx button
      PAUL
      • porter1
        • 559
        remember my clone overheated even with fan underneath,i now have a fan fitted from the internal power on top and one underneath,never even gets warm now,mine is a clone aswell,lucky i know someone good enough to fix it
        • waj_uk
          • 175
          if i pull the connector and leave it will that fk my box up!?
          i think im gonna leave it as it is as it only happened once but i will see what it does n the morning
          thanks for you help guys
          • gsmtech
            • 264
            The fans are low quality and are pretty crap. That loud whirring noise means the fan bearing is on it's way out. The noise will return at some stage,.
            Same thing happened to my'n, I managed to sort it out for a while by lubricating the fan bearing with a drop of oil. Lasted another couple of months and same issue.
            I've removed the internal fan now, and I use a USB powered laptop cooler with a fan that the box sits on..
            Theyre a 1 quid from poundland...Longer term im probably going to find a better quality internal fan and mod it so it switches off when the box is in standby...
