Trouble flashing 500s with dreamup
  • garry1312
    • Oct 2010
    • 2178
    hi im trying to flash my dreambox 500s through dreamup as the pc crashed flashing it with fw pro and caused the box to die on me.
    Right if i select port 5 that will let me connect to it but it only says uploading flash loader yet it is not doing anything.
    in the log it says PM box type: DM500
    then it wont go any further.
    help please.
    Rest In Peace Michael Mcharg, A true friend and although gone never forgotten. 11-10-08.
    Hi try this way,
    1. use dreamup and connect box with com 1
    2. press connect
    3. switch of box
    4. swithon box
    5. box should start downloading.
    Let me know how you got on.
    • garry1312
      • Oct 2010
      • 2178
      thanks mate but have tried that at first and the only one i get anything from is com5.
      • opsmonkey
        • 5379
        are you using a USB to RS232 adapter..?? If so this will be your problem if you are running anything older than XP SP2
        you should be able to select which ever COM is listed, for example mine shows as COM6
        use this guide exactly, step by step, do not deviate from it..
        if it still doesn't work you need to make sure you definitely have a Null Modem cable and not just a RS232
        • garry1312
          • Oct 2010
          • 2178
          yeah its a adaptor that i am using. its definetly a null cable.
          • garry1312
            • Oct 2010
            • 2178
            still not getting anywere with this. its xp im running is there any other way of flashin it with the null cable but not using dreamup?
            • garry1312
              • Oct 2010
              • 2178
              dreamup crashes on me and when i reponen it when i go to connect i get a message saying Unable to open com port, Aborting
              • the man
                • 1660
                prob the adapter there so hit and miss , i could never get mine to work , in the end i dug out a old pen2 pc and linked it to my telly, have you tryed different virsions of dream ups?
                • reddevil157
                  • 1427
                  Might be worth trying older an older version of dream up.
                  • garry1312
                    • Oct 2010
                    • 2178
                    thank, i have tried bout 3 versions in total and no joy with either.
                    Just going to try it out on the laptop instead will let use know how i get on.
                    • reddevil157
                      • 1427
                      Think there's about 5/6 versions of dream up, you might aswell try the rest of them now m8. Pot luck.
                      • garry1312
                        • Oct 2010
                        • 2178
                        still no joy
                        could it maybe be the drivers on the the adaptor and do use guys know of any of any drivers that will work, tried out a couple other ones myself but really not having any luck with them.
                        so any suggestions would be great guys i've been trying this and trying that and going through thread to thread.
                        • opsmonkey
                          • 5379
                          The adapters don't really work with Vista full stop.. You need a PC with XP or a even better one with a RS232 port
                          • garry1312
                            • Oct 2010
                            • 2178
                            its xp ive got on my comp and laptop mate. any idea on how to get it working on xp mate. thanks
                            • reddevil157
                              • 1427
                              Took me ages to get mine going too, bought a usb to serial adapter off flea bay and a null modem cable, or so I thought. Ended up getting a Belkin adapter from my m8 and a "true" null modem cable from Maplins and it worked no problems, after a few versions of dream up too.
