received my dm500v8 today, flashed stb,scanned ok, set up cccam 2.1.3.ok but do i enabled dhcp and leave it enabled in both areas or do i enable wait and then disable,has any onyone got a short tutorial on setting this clone stb up,i have also tried pli jade,darkstar 2,thanks in advance.
dm500v8
just flash, and dont touch settings. just add the magic to var/etc and delete ecm info in var/script. done 200 plus of these and thats all i do.received my dm500v8 today, flashed stb,scanned ok, set up cccam 2.1.3.ok but do i enabled dhcp and leave it enabled in both areas or do i enable wait and then disable,has any onyone got a short tutorial on setting this clone stb up,i have also tried pli jade,darkstar 2,thanks in advance. -
what do yo mean by magic to var/etc,sorry for my ignorance but im really clued up on the cable side as i have sorted many out,but iknow it should be the same but lost with all this new software..thanksComment
your config/c line is the magic, unless you intend to use as freeview box. think you need to a lot of reading, google cccam, you will find what your looking for. its not as easy as cable, my 6 year old could do that, but its not hard once you get your head round it, but you wont get same channels as on cable without the little bit of magicLast edited by mark8393; 16 December, 2010, 00:42.Comment
Tony we do not allow cardsharing discussions here, which is why Mark hinted at what to do. Google will help with those keywords or I am sure someone may help you via pm.
For the general Sat set up of the DM500 you will find all you need here on the forum.
BTW Mark that's a big family you have.I refuse to answer that question on the grounds that I don't know the answer. - Douglas AdamsComment
very sorry for comments,please delete my entries..thanksTony we do not allow cardsharing discussions here, which is why Mark hinted at what to do. Google will help with those keywords or I am sure someone may help you via pm.
BTW Mark that's a big family you have.Comment
