dreambox 500s stuck on green light
  • tony2803
    • 266
    a m8 of mine wrang me today with a problem,his dreambox 500s is stuck on green light,will not respond to remote control at all
    he is panicking a bit as he has three little kids and the prospect of no telly over xmas and three screamming kids and a moaning wife is worrying him a bit,is there a solution to this problem or does my m8 have to enrol into a monestary over festive season for peace and quite,[ive told him it could be monestary ]
    thanks in advance.
  • mario123
    • 383
    thanks in advance.
    think if it wont do anything at all he have to reflash it mate
    • kdol
      • Sep 2009
      • 45
      thanks in advance.
      Probably a reflash will fix this. The simplest way is with FlashWizard if you do not have either the null serial cable or serial connectors on your computer.
      If you do have both of these use DreamUp.
      • mtv1
        The Stig PT
        • 4413
        yes that should do it although dreamup easier imo Digital Kaos - Downloads - dreamup 1.3.2.1 here
        • tony2803
          • 266
          thanks lads will give it a go and see if it will cure problem..
          • the man
            • 1660
            unplug it and re plug it up to ten times , its worked for me in the past.
              Just make shore your friend has not pressed the radio button or you may have damaged the tuner because this boxes have a very delicate tuners.
              • freakazoid789
                • Dec 2010
                • 89
                rebooting always helps
                • plasterer
                  • 1631
                  thanks in advance.
                  Take the lid off it and replace the ribbon
                  It will have just come loose
                  2 min job
                  Hope this helps .................Paul
                  If your Happy with the Help push the Thanx button
                  PAUL
                  • barlovento
                    • 8
                    don that still green light freeze
                    • The Reaper
                      • 73
                      Just reflash------if that doesn't cure then box may require jtag.
                      regards.
                      Col.
                      "Everything I do is legal---I think."
                      • tony2803
                        • 266
                        sorted
                        i got it sorted,nice chap took out tsop chip and replaced with newly flashed chip working great now..cheers all
                        • alextan1116
                          • Jul 2011
                          problem
                          my dreambox also facing this problem,it stuck at the start screen ==
                          • dave2014
                            • Oct 2008
                            • 68
                            Me also, just got a brand new black dm500, flashed new image and was working great. Updated the bouquets and rebooted and now it just shows the nabilo boot screen and reboots constantly. Tried to connect via dreamup and serial but no use it cannot see my box. I use a serial to usb adaptor but this has always connected to my dm800. Could the serial usb adaptor still be the problem even though it works for my dm800. Any help would be greatly apopreciated as its drivin me mad
                            • dave2014
                              • Oct 2008
                              • 68
                              It was the usb to serial adaptor causing the problem, I dug out my ancient little old pc with a serial port and it worked a treat and dream-box was found straight off. I was really prairie dogging for a while there, I knew that old pc would come in handy one day ;-)
