help setting up dreambox 500 with VM superhub
  • chazkelly1985
    • 11
    hi guys hopefully you can help me
    i had my dreambox up and running great then 2 days ago i switched from sly broadband to vergin media 50meg superhub
    the superhub is a modem and router in 1
    so my dreambox went off as expected as soon as the sly bb went off, but i cant seem to get my dreambox connecting to the net now
    heres the details i have so far
    ip of router inside super hub: 192.168.0.1
    ip of modem inside superhub:192.168.100.1
    ip of pc connected to superhub (working fine) 192.168.0.3
    ip i set the dm to : 192.168.0.11
    nameserver i set to: 192.168.0.1
    gateway i set to : 192.168.0.1
    netmask was the same so its 255.255.255.0
    but when i try to go to addons via blue button i get : cannot resolve hostname! (url http://download.blue-panel etc etc
    any ideas
  • smirnoff_rules
    • 8603
    look here if l was u l would change settings and turn into a modem only and use your old router again http://www.digital-kaos.co.uk/forums...er-hub-187920/
    • portbhoy
      • 717
      Cant you just set the dhcp on in the dreambox and reboot it then it will find it's own ip.
      • chazkelly1985
        • 11
        how do i change the settings to turn it just into a modem, i could handle that
        i tried to use the dhcp but it still wont work, it changes everything netmask goes to 255.0.0.0, and the ip adress goes to 10,0,0,24
        when i put my settings in it(which i think is right) i can see the dreambox on dcc and it says there is a network, but still cant access the addons bit
        • smirnoff_rules
          • 8603
          click on the link in my post above
          • portbhoy
            • 717
            Glad I read this tho just cancelled
            • chazkelly1985
              • 11
              oh damn it, thought it would be good with having 50 meg, problem is i dont have another router that i could use, i was on asdl with sky and we have 2 laptops that we use wireless
              would it be possible to hook up the dreambox to a pc via a crossover cable and get it working that way? or would the super hub block it?
              • chazkelly1985
                • 11
                failing that its either getting a full sub from virgin with another box (really dont want to do that) or running a eithernet cable to my neighbours router and using that ggrrr
                • smirnoff_rules
                  • 8603
                  all u can do is wot portbhoy said and reboot everything
                  menu > setup >settings > network settings > click on the dhcp and reboot
                  • chazkelly1985
                    • 11
                    thanks guys guess im stuck with this superhub then, thanks for the time trying to help really appreciate it
                    • Curious123
                      • 2591
                      any ideas
                      Your nameserver is wrong m8 it should be 194.168.4.100 or 194.168.8.100. Change those and you should be fine .
                      • chazkelly1985
                        • 11
                        thanks curious123 but it still wont work, do you have the superhub, or do you know what settings i should be putting in for all ip's
                        • Curious123
                          • 2591
                          My colleague at work has got a superhub and says its great, I would love to get one but everytime I try and get one off virmin they just turn me down. If you still have your old modem and hub then its worth re-connecting it back up again to make sure everything works. If it all worked then I would swap over to the superhub and see what happens. I have never seen an option in hub to configure a nameserver in a router but I have seen this option in a dreambox and in this case I always configure as 194.168.4.100 & 194.168.8.100
                          • whyzer
                            • Nov 2011
                            • 9
                            Hi guys,
                            can u please help i have a similar problem to chazkelly1985!!
                            I have got 2 dreamboxes! a 500hd & a 600pvr
                            both have their own c-lines, their own Ethernet cables
                            but i can only watch one at a time??
                            really baffled?
                            • TheCoder
                              • Jun 2011
                              • 693
                              Generally, its acceptable for the nameserver to point to your local router, which can then check any local network resolvers before passing the request to the next nameserver up the chain (the internet). During booting, the modem will normally be given the ip of the next higher nameserver by your provider configuration.
                              You can, of course bypass a lot of this by setting default nameservers in either windows or linux OS's which effectively then sends all your dns requests to your named dns server. Using the google or OpenDNS servers can make surfing far smoother than using the VM default nameservers, which seem extremely slow to update (it often takes 24-48 hours for VM to pick up IP allocation changes).
