Flashing problem
  • awj
    • 14
    Flashing problem
    Hi
    I flashed my dm518s with this image
    Darkstar v II Emu 2.2.1 Skin Rihanna By Roniothman
    Now, the receiver will not switch on, it tries to boot, gets to the splash screen then cuts out.
    I cannot get DCC or DreamUp to recognise the box.
    Any ideas?
    Would really appreciate some help as I am a DM newbie.
  • Curious123
    • 2591
    Check to make sure you have flashed the correct image for your box. You could just have a bad flash and maybe need to reflash your box but try a different image.
    • the man
      • 1660
      "I cannot get DCC or DreamUp to recognise the box"
      sounds like a power problom , if your using a 2/3 pin adapter try a differnt on, some times the shaver ones wont work to good.
      • awj
        • 14
        Hi
        Thanks for the fast help.
        It was a problem with my RS232 adapter - I used an old PC with a com port and everything is up and running!
