satelite fix
  • ANALYSE_THIS
    • Mar 2009
    • 50
    satelite fix
    hi all,
    wondering if anyone can point me in the right direction. i have a dreambox 500s, ive flashed my box with nabilost darkstar 2 had no problems doing this ive even managed to install ccam 2.2.1.
    i have a motorized dish and want to scan satellites now. this is where i am stuck gone into service searching checked sat config which is set to many satellites via disEqC rotor can see sat position,LNB, 22khz Hi/Lo,Voltage H/V. can see sats ive never herd of like Pana**** 9 (58.0W).
    Motor config
    Use gotoXX fuction is ticked
    Longitude 0.000 East
    Latitude 0.000 North
    do these need to be changed
    When i try scanning i can see that my motor sat isnt moving checked everything all wired up checked with my other box and it moves.
    Any ideas how i can get my dish to work with my box.
  • Desitv
    • Feb 2011
    • 16
    Download satellites.xml generator / transponder .ini generator past to dm
    • ANALYSE_THIS
      • Mar 2009
      • 50
      Originally posted by Desitv
      hiya ive downloaded the xml, ini file for sats i would like to recive. where next
      • mcmlxviii
        • 36
        You need to input your longitude and latitude into the settings.
        • ANALYSE_THIS
          • Mar 2009
          • 50
          Originally posted by mcmlxviii
          hi there i have found my long lat settings how do i put a - in using remote control thanks
          • mcmlxviii
            • 36
            You change the settings from east to west
            • ANALYSE_THIS
              • Mar 2009
              • 50
              entered settings i can now drive the motor to 0
              • mcmlxviii
                • 36
                Dish should move when you select a channel to watch
                • ANALYSE_THIS
                  • Mar 2009
                  • 50
                  dish now moves then the screen displays turning to 5.0 no channels. bbc 1 works
                  • mcmlxviii
                    • 36
                    What is your SNR and AGC (can be found by pressing OK button on remote)
