loading image on clone
  • mickymcg
    hi lads have a new clone 800hd,
    trying to load a new image, have image,
    what is the best loader in the dreamup section,
    thank,s mick.
  • Fergal
    • Aug 2008
    • 1007
    You dont need a loader just turn the box on when you see dream mutimedia press and hold the power button until you see "stop" let go and you will see an ip that your router gave it
    then open ie put the ip in press enter then you will see upgrade firmware at the bottom click on it then browse to the image and flash it wait until its finished takes about 3mins
    oh and make sure you flash the correct image for the sim in your box.
    • wilf
      • 1618
      i find dm800 can be flashed best via the webrowser http://www.digital-kaos.co.uk/forums...-dm800-122157/ no need for the dreamup unless you have no ca found error
      • cris808
        • 133
        Just make sure you use the correct image for your bootloader and sim mate otherwise you will get the CA Error.
