Enigma 2 Download
  • shaf007
    • 23
    Enigma 2 Download
    Hi Guys My dreambox 800 hd has started to play up.Its was working all fine Untill yesterday.When ever i go into addon menu to download epg and any other settings from the enigma 2 it come back with a error saying sorry connection failed...ive even tried a reset and new dreambox elite image and still no joy....The thing is that the cccam was working and i was geting all my channnels....Do u think there is a problem with the the memini server?Any advise would be great thanks
    Shaf
  • andersjay
    • 53
    are you not getting channels anymore? maybe check your connection to router
    • shaf007
      • 23
      Not getting any channels now as ive uploaded a new image dreambox elite but even on this image i cant download anything from the addon menu...Ive checked my router also it works fine...not sure whats going on..
        check your ip address is correct on your box and router and make sure your ethernet leads haven't come loose.
        • shaf007
          • 23
          Ip is fine as i can ftp into the box...its a strange one...Just cant download any settings from the enigma server?Comes back withh sorry connection failed.....
            It's deffo a problem on your network m8, i'm running Dreamelite too and just checked and connected no problem.
            • andersjay
              • 53
              Goto menu/setup/system/network and run network test, see what you get.
              • shaf007
                • 23
                Cheers Bulldog thanks for checking your settings....strange
                ive checked all seettings in menu/setup/system/network and run network test, All come back with green tick...
                Need to check my router again...but all my laptop and pc are working fine...also the cccam is working fine...
                Just the addon menu...will have a play around when i get home tonight..Thanks for you support guys
                Will let u know what i find
                • Curious123
                  • 2591
                  The Dream-elite team do not have a server anymore so you won't be able to download anything from that image server.
                  • shaf007
                    • 23
                    Thanks for the info mate so when did they stop the server?
                    So do they use the same server as the Nabilo blackhole image as thats the one i was using before i changed to dream elite and had the same problem
                    Cheers
                      If it's Unofficial dream elite Phoenix image, then the server is working, if you haven't got this image installed i would suggest installing it as it's an excellent image.
                      • shaf007
                        • 23
                        Cheers Bulldog.Do u have a link for that image,will go home tonight and give it a go
                        Thanks Guys For the info.
                        Ps so when did the server stop working?im sure i used it last week...
                          Free przitaly images Download (Only for NEWB DM800 SIM2)--UNOFFICIAL DREAM ELITE V.133DV3 PHOENIX EDITION
                          • plasterer
                            • 1631
                            Been down for yonks mate
                            Heres the link
                            Only for sim 2.01
                            Lets know how you get on ....................Paul
                            PAUL
                            • blueflash234
                              • Mar 2009
                              • 904
                              there's also the tunisiasat add-on server which will give you every thing the old server gave you
