DM00s is bugging me
  • dssunder
    • 22
    DM00s is bugging me
    how hard is it to set up a dreambox?
    how would i get a lock i have good signal and still nothing
  • Grizz
    • 1598
    borrow a box that you know is set up for the satellite you are aiming at. plug it into your dish. then you know if your dish is out or if its a box problem
    • dssunder
      • 22
      i dont know anybody that has another box is their a troubleshooting guide
      • Grizz
        • 1598
        is there free to air channels on the satellite you are aiming at?
        • Grizz
          • 1598
          Originally posted by dssunder
          my light is is always on its red and cant power off when i press power button on remote is this normal
          mate, i reckon you would be better off putting your all your questions into one thread. light being always red doesnt sound right. try unplugging it and powering up then. you should have a green light to get a picture
          • reddevil157
            • 1427
            If your box is flashed properly, you should be able to go into settings-choose the sat your looking for, go to satfinder in settings, adjust your dish and you will see your signal indicator move up or down in satfinder, I put a portable tv in the window to set mine up.Once you get a strong signal, you should get a lock But if you've a red light constantly, you may need to reflash.
            • dssunder
              • 22
              transponder scan
              Indicates SNR 63% AGC 31% and i dont even have the cable hooked up is this right
              • mark8393
                • 2305
                yes it will show that without coax connected, you wont get anything until you connect. setup and report back
                • dssunder
                  • 22
                  DM500s is setup with
                  ok everything is working now i pointed my dish to 97W and adjusted the LNB skew and now have channels.
                  Now i have a question as to if i can put files on my DM500s without using FTP as I have no network. Is there such a program that exists or is it possible to do it through linux
                  • Grizz
                    • 1598
                    edit
                    sorry brain not working.
                    are you just going to be using it for free to air channels? you need a network for anything else
                    • dssunder
                      • 22
                      i want to load key files theres has to be a way to load files other than ftp, but then you need a network for the files to work right
