Dreambox 800HD Juddery/Stuttering CCCam
  • mehstg
    • 10
    Hi guys
    I have a dreambox 800HD connected to a dish pointing at 28.2e. I am picking up the full s*y package with good signal, and the FTA channels work perfectly.
    I am having issues with CCCam and Cardshare however.
    I have contacted about 4 different cardshare providers on this forum for test clines and installed them. This works and unscrambles the picture, however I keep getting juddering, almost as if the server is slow and not sending the codes quick enough.
    To start off with, I blamed the servers...and kept searching for a better server, however after four different providers with the same problem, I am guessing the issue is at my end!
    Any ideas if this is a common problem. I am running OpenPLI 2.0, and rolled back to Pli Jade3 to see if this made any difference.
    I have Virgin 20mb broadband, and generally get a good speed with a 13ms ping.
    Not sure if it is OK to speak about cardshare on this forum, so mods delete if necessary!
    Thanks!
  • junger
    • 200
    No Cs Talk
    look around on Google m8 but no cs talk here
    If only I had more time that I could waste
    • cactikid
      • 12017
      check internet connection as mine glitches because i am on a dongle,also check box is well ventilated
      • SGTFlipFlop
        • Sep 2009
        • 1002
        What revision of tuner does your Dreambox 800 have? It might not be the server at fault it might be an old tuner
        • garry1312
          • Oct 2010
          • 2178
          hey would say it sounds like a tuner issue. is it only certain channels and is it HD channels.
          How you finding the Pli images on the 800 i tested them and found them very basic. thought they were like a 500s image.
          Rest In Peace Michael Mcharg, A true friend and although gone never forgotten. 11-10-08.
          • mehstg
            • 10
            Thanks guys. Sorry, won't mention c/s on here again! Turned out to be a run of bad servers. All working perfectly now.
            Finding PLI ok at the moment although I haven't tried anything else to compare it to. Lots of people on here seem to use Nabilosat so I might give that a try. What are you using?
            • owenb
              • 703
              i use pli find it works perfectly for wahat i need its a personal choice tho
              • andy91
                • Aug 2010
                • 3583
                Your not downloading torrents alot are you when the box is on?
                This affects it.
                Andy.
                • mehstg
                  • 10
                  No. I don't use torrents. Turned out to be a server issue. Using a new history now and all is perfect.
                  Considering flashing the box with Nabilo BlackHole to try it out. Anyone know if it is clone safe?
