im almost there, i think ! please help if you can
  • kristinn76
    • 17
    hi.
    i am not getting any channels through on my dm800.
    i get no data on transponder. i have transfered sgt flip flops bouquets to my dreambox and i get a signal from every channel i put on ranging from 57 to about 90 but no picture.
  • father ted
    • Feb 2008
    • 1389
    Originally posted by kristinn76
    hi.
    ok how are you expecting to get picture?do you have a sky card?or are you cs?can you explain a little more what your doing ?
    • kristinn76
      • 17
      im am going to cs, but arent there some channels that would get through, that arent locked i mean? , i have tried e4 and bbc but nothing is geting through
      • father ted
        • Feb 2008
        • 1389
        yep your spot on you should be getting some fta channels like bbc1 and the likes what cam do you have on it? and have you enabled it not that should matter for fta channels
        • kristinn76
          • 17
          errm...how do i enable this cam thing? im sorry mate im a total noob
          • father ted
            • Feb 2008
            • 1389
            wot image is on box? is it a motorised dish?are you searching 28.2 ?
            • kristinn76
              • 17
              Im static, yes im searching 28.2 and the image is Gemini 3 it was on the box from Tony.
              but it say's Loading enigma2 constantly in the lower left corner
              • father ted
                • Feb 2008
                • 1389
                dont sound right to me mate if its constantley saying loading ,do you know how to flash an image to it?did he say it was all ready to use?is it a clone do you know?
                • kristinn76
                  • 17
                  yeah i have flashed a few through the browser. it's a clone dm800 pro.
                  is there an image you would recomend for me?
                  • kristinn76
                    • 17
                    oh... and no he didnt say if it was ready to use.
                    • father ted
                      • Feb 2008
                      • 1389
                      ok were getting there first we need to find what bootloader it has and sim as we dont want to fry it im sure theres a few on here that would be suitable i have a vu+duo so am not really sure about yours
                      • andersjay
                        • 53
                        If its sim 2.01 use this image UNOFFICIAL DREAM ELITE V.133DV3 PHOENIX EDITION,
                        • andy211081
                          • 575
                          read the thread you started on Monday
                          as i had exactly the same problem
                          take out the tuner: [ame=http://www.youtube.com/watch?v=FwGz84eL2LU]YouTube - Smontare Dreambox dm800hd e montare la ventolina[/ame]
                          then clean with a rubber gently, put back in and mine worked fine.
                          Did the scan and got all the channels..
                          I had exactly same issues as you and mine worked after taking it to bits
                          Let us know if that worked?
                          Ladies and Gentlemen, this is your captain speaking. I have the only gun on board. Welcome to Con Air.
                          • kristinn76
                            • 17
                            Thanx Andy.. i will try that m8.
                            Did u also have the loading enigma2 thing getting stuck going on your box before u fixed it?
                            ps my box is a bit different then the one in the video, it's the pro version and it has a golden square instead of a black one inside under the fan.. ?
                            • andy211081
                              • 575
                              it will be fine will come to bits the same way ..i watched the video after i had taken my box to bits
                              just gently take out the tuner which is like a graphics card in a pc.
                              I added a new image first though before i did anything
                              Try it and see how you get on
