DCC Problem
  • snake7
    • Apr 2011
    DCC Problem
    hi,
    I am having prblems with the con fig file on my DM800 DCC, when I go to edit the file, I delete the script in there, replace with new it then ask if I want to save which I do, but when I go to view the con fig file, it has not saved the new and the old is showing again, so basically, its not saving any changes done to the con fig file, I have also tried renaming the config file but this also will not save, any ideas please, thanks...
  • firestorm
    • 1550
    try checking the file attributives are set to 755 also when you have made changes to a file make sure you restart your cam
    • snake7
      • Apr 2011
      Did all that and still not saving, its as though its letting me read but not write...I get this message but means nothing to me..
      < 150 Here comes the directory listing.
      < 226 Directory send OK.
      ! 6343 bytes received/sent in 31 milliseconds
      > SIZE CCcam.cfg
      < 213 4096
      > SITE chmod 755 CCcam.cfg
      < 550 SITE CHMOD command failed.
      • firestorm
        • 1550
        hopefully one of the lads that use DCC will help you as i have not use it for a long time as i have a mac
        • southpaw
          • 2233
          i use a dedicated ftp programme mate , filezilla , free btw
          load it . click on etc folder ,right click on cccam.cfg file and select view/edit , paste your details in , click save , select yes to reload it back to etc
