problem read Sky card
  • okverd
    • 10
    Hello everyone, I hope someone can help me this is driving me crazy.
    I followed a tutorial of using latest Oscam to get the white card working in the internal slot. Im using a clone DM800, image latest Nemesis 2.2 with 76D bootloader.
    All working fine, just sometimes small freezes and EcmOK show max 76%. I have only 4 user acounts.
    Please have a look if my configs are good.
    Why I cant get EcmOK better reading?
    Do I need insert the boxkey?? Now working without boxkey.
    Maybe I have to buy better card reader: Smargo, or Emikey reader??
    Thank you very much for help.
    ====Oscam.cfg====
    [global]
    nice = -1
    WaitForCards = 1
    ClientTimeout = 5
    CacheDelay = 120
    logfile = /usr/local/etc/oscam.log
    [newcamd]
    Key = 0102030405060708091011121314
    Port = 34000@0963:000000
    === == Oscam.Server ===========
    [reader]
    label = SkyUK
    Protocol = internal
    detect = CD
    device = /dev/sci0
    Group = 1
    EMMCache = 1,3,2
    #BoxID = xxxxxxxx
    CAID = 0963
    ident = 0963:000000
    ==== Oscam.User =====
    [account]
    user = user
    pwd = pass
    group = 1
    au = SkyUK
  • jfish
    • 799
    ====Oscam.cfg====
    [global]
    nice = -1
    WaitForCards = 1
    ClientTimeout = 5
    CacheDelay = 120
    [newcamd]
    [reader]
    label = SkyUK
    Protocol = internal
    detect = CD
    device = /dev/sci0
    Group = 1
    EMMCache = 1,3,2
    #BoxID = xxxxxxxx
    CAID = 0963
    ident = 0963:000000
    [account]
    user = user
    pwd = pass
    group = 1
    au = SkyUK
    The freezing may be due to the card being overclocked - set the following in the oscam.server file under reader section
    mhz = 357
    cardmhz = 357
    • dctyper
      • 2539
      simple dont use oscam use cccam
      clocking the card in and internal reader does not work it is set to default.
      dc
      • Ansem
        remove the # from this line and reboot
        #BoxID = xxxxxxxx
        • davvo
          • Apr 2009
          • 666
          this is just for local card 0963
          just use these lines
          dont keep adding things
          keep it basic
          chmod the files
          right click the file click attribute
          for all oscam configs its 644
          oscam bin is 755
          [global]
          nice = -1
          WaitForCards = 1
          logfile = stdout
          preferlocalcards = 1
          saveinithistory = 1
          # protocols
          [newcamd]
          key = 0102030405060708091011121314
          port = 12000@0963:000000;12001@0963:000000
          [reader]
          label = slot1
          protocol = internal
          device = /dev/sci0
          boxid = yourboxid
          blockemm-u = 0
          blockemm-s = 0
          blockemm-g = 1
          blockemm-unknown = 1
          emmcache = 1,3,2
          group = 1
          caid = 0963
          [account]
          user = user
          pwd = pass
          group = 1,2
          au = 1
          caid = 0963
          • jfish
            • 799
            #BoxID = xxxxxxxx
            the new version doesnt require the boxid as it detects if when the card is read.
            • dctyper
              • 2539
              this is way too complicated and can cause the glitching you are getting
              follow my guide for perfect viewing
              dc
              • gsmtech
                • 264
                dc
                You may not have a choice soon, have you noticed PickTV doesnt clear if you use CCCam to read the card ? This channel clears fine with OScam..
                This is reported to be due to testing of a new anti CS algorithm, so if other channels, sports, movies etc get moved to the new scheme...CCCam wont clear them anymore...now as CCCam is not actively developed anymore...the only option is to swap to OScam..
                I would start looking into OScam if I were you..
                • okverd
                  • 10
                  Thank you very much for your answears.
                  Yes, I want to use only Oscam, but Im not happy with the freezing. Ecm is low @100ms.
                  Im tried many Oscam settings and sat boxes DM500, DM800, DM8000 and still same.
                  Just desaded to buy external card reader - Smartmouse:
                  Smartmouse Easymouse 2 USB Programmer Neu | eBay UK
                  Then easy to change voltage to 3.3V, because in SKYBOX from SKY the card is readed 3.3V and in Dreamboxes 5V.
                  Please point me if Im wrong.
                  Cheers mates
                  • davvo
                    • Apr 2009
                    • 666
                    try a newer version of oscam
                    to upgrade oscam
                    download the version you want from ump2002.net
                    unzip and you should see all these files (below)
                    pick the one for your box mine is DM800
                    SO I USE
                    oscam-svnX-mips-tuxbox
                    rename it to oscam
                    ftp to usr/bin
                    and click 755
                    restart oscam
                    that will upgrade oscam to the version of your choice
                    now to change the name of oscam version
                    you have to do it manual
                    ftp to /usr/camscript
                    find your oscam
                    right click the file click rename
                    example if i was to upgrade to Oscam4856
                    from Oscam2901
                    i would rename this
                    Ncam_Oscam2901_CCcam213.sh
                    to this
                    Ncam_Oscam4856_CCcam213.sh
                    now when you push the blue button it will show the correct version
                    - oscam-svnX-arm-coolstream            Coolstream
                    - oscam-svnX-x86_64-pc-linux            64 Bit Linux PC
                    - oscam-svnX-mips-freetz            Fritzbox Router
                    - oscam-svnX-mips-tuxbox            DM500HD, DM800, DM7025, DM8000
                    - oscam-svnX-powerpc-tuxbox            DM500, DM500+, DM600, DM7000, DM7020
                    - oscam-svnX-tripledragon            Triple Dragon
                    • jhalvarez
                      • Apr 2011
                      what is te lastest oscam?
                      • jhalvarez
                        • Apr 2011
                        can oscam read p5 sky card?
                        • jhalvarez
                          • Apr 2011
                          I?ve measured the supply votaje to the card in the new dreambox 500s clone and it has 3.3 v, maybe the old boxes had 5v, I read a p3 sky card and it works fine.
                          Those boxes don?t need any change in the power supply of the drambox 500s.
                          • davvo
                            • Apr 2009
                            • 666
                            it changes by the day/hour
                            as of now its oscam-svn5001
                            im using build 4856
                            • okverd
                              • 10
                              davvo - thank you very much.
                              Im upgraded Oscam, switched off Cccam and turned "dvbapi On" Now its look great no more freezing and ecm is only 10 ms.
                              You are top geezer mate..
                              Many thanks again for help
                              ta
