3G dongle
  • skydive80
    • May 2010
    • 168
    3G dongle
    Hi again guys
    I want to take my box around my friends house who has a sat dish but no internet at his house so i was wondering if i could use a PAYG 3G dongle to get all my channels and would it take a lot of bandwidth?
    I have DM800 with the blackhole phonix.
    Many thanks
  • SouthernComfort
    • Feb 2011
    • 403
    Originally posted by skydive80
    Hi again guys
    Many thanks
    Do not think a 3G dongle can be plugged directly into a DM800 as it needs to be configured, can be used through a router quite effectively though. uses very little BW.
    "What we've got here is failure to communicate."
    • MrFug
      • 880
      3G dongles need drivers to make them work, and the DM800 doesn't have them. You can get it to work by using a 3G router, then connecting the Dreambox to the router, or even by using a latop and Internet connection sharing.
      Also, CS doesn't use much bandwidth but its "time critical", meaning even a little drop in signal will result in a few glitches/freezes.
      I could be wrong, but I think that's how it works atm.
      • skydive80
        • May 2010
        • 168
        I have tried the internet sharing when trying to make my xbox go on line via my laptop but with no luck using xp, I think I might have to go down the Linux aircrack way but would love to do it via 3g or get my laptop to go wireless
        Sent from my HTC Desire using Tapatalk
        • bob114
          • 192
          hi
          How to connect dream box using 3g, GPRS or HSPA
          1. Connect your USB dongle to computer and connect to the internet.
          2. goto run menu and type cmd or
          accessories Command Prompt/ Programs /start
          3. you will get dos command screen
          4. type ipconfig
          5. You will be given two ip settings, you might see on top 192.168.0.1 or some ip range.
          7. Connect your dream box to tv and connect your computer also, if you connect using directly, you should use cross cable to connect your computer.
          8. you should share your network connection, to do that
          network connections / settings
          9. start select your 3G or GPRS connection.
          10. click right mouse button and select properties and select advance tab on the dialog box and on the internet connection sharing tab select allow user to share my internet connection
          click ok button and close it
          Then go to dreambox on the set ip address as if you computer ip communication settings settings menu is 192.168.0.1 then select your ip as 192.168.0.2 then Set gateway as your computer ip ?192.168.0.1? and name server also same ip rest of the things same.
          Save it and close
          Wait till online comes and try to browse channels
          hope this may help
          • skydive80
            • May 2010
            • 168
            Thanks for this bud I will give a go in the morning, what OS does this work on?, my laptop runs xp.
            • mtv1
              The Stig PT
              • 4413
              get a 3g router m8 Home Networking, Building to Building WiFi, HomePlug Turbo, HomePlug AV - solwise.co.uk a lot easier than messing with you lappy although the help is well done , its too complicated , and you'll have wireless internet in the house sweet
              • thecelticfan
                • 98
                I use a Globesurfer III
                Great gadget.
                3g with 2 x lan ports to plug in the DM and wireless.
                • SouthernComfort
                  • Feb 2011
                  • 403
                  Much cheaper alternatives
                  TP-Link TL-MR3220
                  TP-Link TL-MR3420
                  • blueflash234
                    • Mar 2009
                    • 904
                    the TP-Link TL-MR3420 is a great little router it can use 3g or wlan you wont regret buying it
                    • bruce_ica
                      • Aug 2009
                      • 18
                      i have this router but when i try to get it to connet with the 3g router only will not work in dreambox have tryed 2 dreamboxs but works fine with krytview can anyone help me thanks
