I have db800 and cannot get narration turn off. There is no audio button on remote. I am using darkstar2.In av settings AC3 default is set to yes and ac3 downmix is no . I have tried changing these but make no difference.
Turn Narration off
if your remote has,nt got an audio button then press the help button on the remote. you will then see a list on screen.
scroll down to audio then change the language from eng nar to engdm500hd -dm500hd v2-vu+duo- triax 1.1m - inverto lnb - technomate 2300 motor- linksys ddwrt routerComment
when the dm8000 came out it came out with same remote as the dm800 but with a couple of changes this is why i said try the yello button as im more than sure when i tryed it on an 800 it worked i never had to remap any of the buttons to get it to work it just worked that wayAttached FilesComment
i was having same issues so i contacted the seller in china and he told me the reason
they removed the audio button was so they can add 4 more buttons and the new dm800 remote will work with the dm8000 to.
they were having compatibility issues with the audio button sot hey removed you can use yellow button for audio or press help and select audio from their.Comment
Just received one of these remotes and can confirm my Yellow button works as the audio button now
, is it a dm800 u sure???? if it is change the image to open pli or something similar
PAUL
