DM800HD Image
  • alom5
    • 1648
    DM800HD Image
    i ffd up my box now having to flash it.
    it had the gemini project 2 image on it.
    i have found a image called merlin excalibur image.
    i would like to know if anyone has had any experience of this image and if its any good.
    by the way my system crashed because i tried putting crossepg on it. so i dont want gp 2 on it now.
    thanks.
  • C64
    • 2394
    I've not owned a DM800 for over a year now, but my advice is to stick to images from the big boys in the scene such as Nabilosat and PLi, there are many other superb images but until you find your footing I would stick to the big boys as they have superb support.
    • owenb
      • 703
      excalibur is an ok image i used it for a few days kept getting hte dreaded green screen when it downloaded an epg switched to openpli and would never change it now unless i have probs
      • markshore
        • Oct 2010
        • 120
        Hi i had Gemini 5.1 had problems to changed to Peter Pan 2.3 good image also has cccam 2.2.1 installed as default.
        Now running EDG Nemesis 2.2 also a good image the good part about this image is that it does not keep restarting E2 everytime you do something and it will tell you when updates are due and the best part is that you do not have to keep flashing a new image everytime (cccam is available through the extra download addon).If your box is a clone you need to look for clone safe images and both the above are available.
        GENESI-PROJECT
        Regards
        Mark
        • alom5
          • 1648
          GENESI-PROJECT
          DM800 Clone Patched Images for Sim2.01 #76
          Regards
          Mark
          thanks for the info boys.
          out of all the mentioned images, which one would be the easiest in terms of getting the epg working sweet!!?
          • blizard442
            • Sep 2009
            • 203
            open pli, well supported and covers all your needs
            If You Like My Post -----------PRESS THAT THANKS BUTTON
            • markshore
              • Oct 2010
              • 120
              Mine works ok EDG Nemesis 2.2 uses crossepg and I am using Rytec source.
              Regards
              Mark
              • alom5
                • 1648
                Regards
                Mark
                i managed to get the said image on and working.
                but for the life of me cant get ccam to work. got it installed but when i select it from the blue button, it says starting.....but then when you press blue button again to check....shows none.
                any ideas before i ditch this image.
                i tried with tar file and manually ftp the files in thier folders and chmod to 755
                same thing both ways. :-(
                • blizard442
                  • Sep 2009
                  • 203
                  never tried this image... could be that they dont support downloads anymore. Move on... i've uploaded openpli for bootloader 82 today, if you have 82 use that.
                  • alom5
                    • 1648
                    i had enigma on. 76c.
                    how do i get 82?
                    • blizard442
                      • Sep 2009
                      • 203
                      how do i get 82?
                      82 is currently in development stages... like a beta... so i wouldn't recommend the upgrade YET... until they release the full final release.
                      • alom5
                        • 1648
                        do i have to change anything....or just flash the image i want?
                        • markshore
                          • Oct 2010
                          • 120
                          Hi using 2.2 on Genuine DM500HD perhaps different for a clone, most images no longer come with CCCAM as default so you need to Google for the 'extra URL' for the EDG Nemesis image, place in etc with DCC, RESTART and you will find the extra addon link.
                          Regards
                          Mark
                          • alom5
                            • 1648
                            i've just gone to blackhole and everything seemed pretty simple. just the way i like it!!
                            • lombard
                              • 793
                              hi, i have UNOFFICIAL DREAM ELITE V.133DV3 PHOENIX EDITION flashed works great, super stable, love the skins, epg works great. wondering what does BL82 do ?
