Can you let us no about this box please ive only done cable up till now is it a good price looks like its ready to go just need a sub any thoughts or advice on it would be greatfull thanks in advance link to it.............http://cgi.ebay.co.uk/DREAMBOX-DM-800-HD-PVR-BOXED-SATELLITE-PRO-FULLY-LOADED-/330562599139?pt=UK_ConEle_SatCableFreeview_RL&hash =item4cf710f8e3
Dreambox dm 800 hd.
Looks like a clone, But his feedback is 100% so I think It'd probably be a good investment !
Regards.
Sat Boxes
Dreambox 500s.
Dishes
Sky minidish self fitted. -
this is by far one of the best satellite receivers out there, it runs linux more specifically enigma 2... but i wouldn't but it from ebay... search up on google (ukdreamshop)... they are like 20 pounds more expensive but you get peace of mind and satisfaction from them. he sells it preflashed so all you have to do is plug in... download a few addons such as epg features and CAMS... add a cline and there you go!!! you'll find many tutorials on flashing the box with other images in the relevant dreambox section of the forum.Can you let us no about this box please ive only done cable up till now is it a good price looks like its ready to go just need a sub any thoughts or advice on it would be greatfull thanks in advance link to it.............http://cgi.ebay.co.uk/DREAMBOX-DM-800-HD-PVR-BOXED-SATELLITE-PRO-FULLY-LOADED-/330562599139?pt=UK_ConEle_SatCableFreeview_RL&hash =item4cf710f8e3
you'll never go wrong with this box.If You Like My Post
-----------PRESS THAT THANKS BUTTON
Needless to say i wont be buying the adapter from him thanks for the help mate one last thing ive got the old mini dish any good for that or am i looking for a bigger dish thanx again take it easy..................I know you believe you understand what you think i said
I am not sure you realise that what you heard is not what i meant ! sigpicComment
depends, For 3 oclock kick offs get a motorized dish, for just sky uk, knock yourself out, Minidishes are mint, setanta is also receivable on the sky minidish !
Sat Boxes
Dreambox 500s.
Dishes
Sky minidish self fitted.Comment
if you're techy mate here is the spec for the receiver.
300 MHz MIPS Processor
Linux Operating System
OLED - Display
MPEG-2 / H.264 Hardware decoding
Tuner: DVB-S, optional: DVB-C, DVB-T
Tuner Module, Plug&Play
1 x Smartcard-Reader
V.24/RS232 Interface
10/100Mbit Ethernet Interface
1 x Scart (RGB, FBAS or S-Video)
DVI
2 x USB 2.0
analog modem
S/PDIF Interface for digital bit stream out (AC-3)
64 MByte Flash, 256 MByte RAM
SATA
for use either as internal SATA HDD 2,5?
or to use for extern eSATA
2 x USB 2.0 Host
LNB power and polarisation per tuner:
LNB Current 500mA max.; short-circuit-protected
LNB Voltage vertical < 14V no load, > 11,5V at 400mA
LNB Voltage horizontal < 20V no load, > 17,3V at 400mA
Count of active satellite position:
DiSEqC 1.0/1.i SAT POSITION / SAT OPTION
DiSEqC - Rotor Control
Power consumption:
< 15W at 12V
External PSU
Input:
110-240V AC / 50-60Hz / 0,6A
Output:
12V = / 3,0A
Physical specification:
Ambient Temperature +15?C...+35?C
Humidity < 80%
Size (W x D x H): 195 mm x 140 mm x 40 mm
Weight: 1,8 kg without HDDIf You Like My Post
