Cannot see HD Channels
  • Mario Micallef
    • Mar 2010
    • 20
    #16
    Thanks - We shall do as you guide me... Do you suggest any latest image..
    Once again thanks for your help and co-operation
    Regards
    MM
    • owenb
      • 703
      #17
      i use open pli but image is a personal choice really mate
      • Mario Micallef
        • Mar 2010
        • 20
        #18
        What is open pli ? Please bear with me cause i am not good also how it can be installed etc.... Thanks my friend
        • jaipal2004
          • 25
          #19
          weak tuner - had in on mates DM800HD - wouldn't get HD with the exception of maybe 1 channel. The thing that gave it away in the end was that even the freeview HD stuff wasn't appearing!
          Either get the box swapped or if you fancy some messing - buy an upgraded tuner (links on the forums here) or just do a Google for it. Open your box and see what tuner you have in there.
          cheers
          • Mario Micallef
            • Mar 2010
            • 20
            #20
            But few days ago i was watching all HD Channels .... Thanks
            • father ted
              • Feb 2008
              • 1389
              #21
              i would check your .cfg file and make sure your line is still in there
              • Mario Micallef
                • Mar 2010
                • 20
                #22
                can you please guide how i check the .cfg file... Just to clearify i can see all normal channels but not HD ones... Thanks in advance
                • andy91
                  • Aug 2010
                  • 3583
                  #23
                  Connect to the box with something like Flashfxp you will find it in downloads if you havent got it.
                  Connect to the dreambox and find the file etc,open it and scroll down till you see ccam.cfg.
                  Right click on the file with your mouse and press view there you will see what you need,
                  Andy.
                  • father ted
                    • Feb 2008
                    • 1389
                    #24
                    ok from what your saying you can see all the other channels ,can you see normal sports and movies and such and your saying HD not showing if so its who your getting them off thats at fault if you are seeing normal channles then there is nothing wrong with .cfg file if there was youd see nothing
                    • davvo
                      • Apr 2009
                      • 666
                      #25
                      if you cant clear FTA hd channels
                      like BBC HD BBC1 HD ITV HD
                      then it wont be nothing to do with cfg files
                      take the lid off remove the back plate
                      then slide out the tuner
                      put it al back together
                      you can only try
                      • bubbles69
                        • Feb 2010
                        • 1150
                        #26
                        Sounds like faulty motherboard to me, think tuner is ok i seen one that rebooted everytime a hd channel was zapped the box just rebooted straight away, i reckon faulty tuner or motherboard process of elimation to find out witch is damaged
                        • BlueBox
                          • 573
                          #27
                          Guys i am not getting any sound on few HD channels like sky news decovery Nat geo ect picture ok
                          DreamBox 500HD NewEnigma2
                          • smoggie
                            • 863
                            #28
                            really should start your own thread, have you clicked on audio and tired to change the options there?
                            • andy91
                              • Aug 2010
                              • 3583
                              #29
                              Have you tried them with just a scart? Might be a faulty dvi to hdmi cable i would start with that.
                              Dont think it will be the audio button on remote that normally affects the music channels so give the dvi cable a good shove in mate.
                              Andy.
                              • BlueBox
                                • 573
                                #30
                                Thanks kids turned the AC3 downmix off now all working
