DM800HD
  • valioiv
    • Nov 2010
    • 39
    DM800HD
    Hi i have new DM800HD Pro Alps M Tuner, Sim 2.01 and BL76D i am newbie trying to use gamma but ............nothing on the info bar shows that everything is done but black screen any help
  • owenb
    • 703
    what ar eu trying to run it with oscam???
    • benny/9
      • 1964
      to read the card in box card slot,
      Use Cccam and put in your Cccam.cfg these lines
      CAMKEY: /dev/sci0 11 22 33 44 55 66 77 88
      CAMDATA: /dev/sci0 11 22 33 44 55 66 77 88 99 aa bb cc dd ee ff
      Please Read Carefully!
      • valioiv
        • Nov 2010
        • 39
        bulsat 39.0 but i dont know how to do it
        • benny/9
          • 1964
          Originally posted by valioiv
          bulsat 39.0
          if the card opens bulsat then add the script useing the dcc panel
          add the script at the bottom of your cccam cnf file in the etc folder
          copy and paste it then save,exit the dcc unplug the box and
          re start it this is for the script to be read you can also use a
          patched mgcamd 135a and use keys to open bulsat
          • valioiv
            • Nov 2010
            • 39
            i dont really understand much as i said am new to this stuff so if you explain things to me step by step ill be happy to follow them steps ty
            • benny/9
              • 1964
              to see the files on the dreambox you first need to get
              the [DCC] dreambox control centre on your computer
              and if the gamma card opens bulsat you can add the script
              i posted in the cccam cnf file so the card reader will read the card
              did you flash a image on the 800 and load the cccams etc:
              • valioiv
                • Nov 2010
                • 39
                It coms gemini proj 2 CCcam2.2.1 CCcam2.2.1/OSCCam1.00 CCcam2.2.1.NewCS 1.67
                • benny/9
                  • 1964
                  first is your computer near the dreambox?
                  the cccam 2.2.1 will read your card after you
                  add the script i posted in the cccam cnf file in
                  the etc folder. but first you will need a copy
                  of the dcc panel on your computer and a straight wired
                  cat5 ethernet cable to connect the dm800 to your router
                  then you can add the script in the dm800. if you dont have
                  the dcc then you can download it from the forum
                  Digital Kaos - Downloads - Dreambox Control Center
                  and cat5 cables you can get from maplins
                  • valioiv
                    • Nov 2010
                    • 39
                    thank you very much for your time and help, you have been very helpful. I just don't know what to say thank you so much.
                    • benny/9
                      • 1964
                      hi m8,
                      there's no problem we all help on this forum
                      i take it you have the dm800 connected to
                      your router and have the DCC and you can now
                      copy and paste the script in the cccam cnf?
                      • valioiv
                        • Nov 2010
                        • 39
                        yes i did it wasn't easy but it was my first time so am happy that i managed to do it with your help ty again.
                        • benny/9
                          • 1964
                          is your gamma card opening the chns now?
                          • valioiv
                            • Nov 2010
                            • 39
                            bulsat only
                            • benny/9
                              • 1964
                              bulsat only
                              there's not a lot more open now even if you load the keys var
                              most use the box on the internet via server to get chns open
                              but we cant discuss that on the forum you need to google c/s
                              for more info on that subject.
                              what other chns were you thinking should open?
                              i thought nova did'nt open now on the gamma card?
