problem with hdd on dm800hd
  • camslangman
    • Oct 2010
    • 35
    I have just fitted an internal sata 320 gb hdd to my 800hd it has enigma 2 gemini 5.1 2.oi sim I have initialised the hdd , after starting the process it says after a a few mins process finished . In the process of initialising it asks what file system and gives 2 choices ext 2 and ext3 which is corrct? I have read something about mount the hdd I do not see or been asked to do this . In another section of menu under gemini extas it says something about ftp mount, uername, password, then says-- status ftp not mounted is this relevant.
    I do not see how to start recording or my next step in the process I would be grateful for some help here.
  • reddevil157
    • 1427
    ext 3, find your devices manager and you'll be able to mount your drive. ( try blue twice )
    • camslangman
      • Oct 2010
      • 35
      thanks for that
      OK I think I have done that , in Partition manager it gives Mountpoint:Long no Size of hdd , device:dev/sda , Parameters :rw,data = ordered . Question How do I Start Recording ie,. where in the menu do I go to start a recording.
      • reddevil157
        • 1427
        Ftp to the box and go to media\ hdd and create a folder called movies, if you mapped it right, you should be able to record via your remote red button.
        If I've missed anything someone will spot it
        • camslangman
          • Oct 2010
          • 35
          pressing red button I get a Message saying "Free disk-size too small < 100 mb "
          • reddevil157
            • 1427
            check here to see if you can sort it, if not don't panic, someone will sort ya
            • Fergal
              • Aug 2008
              • 1007
              Go to device manager usually blue button twice and the red to mount points and change the mount point to media/hdd then red to save it should ask to reboot then after it has press red for recording options
              • camslangman
                • Oct 2010
                • 35
                great stuff thanks all I got it at last with your help . I am most grateful finding it to playback is quite a task too
