Box wont boot or flash
  • bends
    • 57
    got an odd one:
    dreambox wont boot.
    power on and i get the dream Multimedia logo winking at me.
    tried using dreamup(1.3.3.4): it will sometimes load the first part, then stops saying waiting for acknowledgement.
    if i use the 2nd stage fix s/w to force the flash button, i select a SSL (tried a few plus full image) but then get "calculating checksum" forever - meanwhile oled is still winking at me.
    moving on, i have taken the sim out and put it in another box. seems to boot ok (i didnt let it finish).
    I have put the sim from the good box into the bad box with results as above, i.e. no boot.
    then i have connected via serial program to the box and watched whats going on.
    with either sim in i get
    (c) 2007,2008 Dream Multimedia GmbH. All rights reserved.
    Dreambox DM800
    FIRST STAGE 1.00 {BO2345
    constantly repeating.
    with sim removed i get:
    Dreambox DM800
    FIRST STAGE 1.00 {BE3E3E3E3E3}
    Second stage loader wasn't found. Don't panic - it's not a (real) problem.
    You don't need to repair your Dreambox. It just means that the flashrom with
    the graphical menu was erased. You can restore this with a tool like DreamUp
    with serial access.
    RESCUE{012
    Anyone out there have any idea what's wrong???
  • IAmATeaf
    • 591
    Have you checked that the SIM is in securely and making good contact?
    • bends
      • 57
      Sim is where i have concentrated and seems ok.
      I bought this box as faulty so dont know its history.
      Anyway, i resoldered the sim pins and lifted the pins up a little. Also removed the optical out connector as it was loose. gave the board a good clean as it seemed to have a residue on it, hopefully not water damage.
      I dont know if i have progress or not but i have go something different:
      if i use the dreamup version which says V2009 patched by forhike and natas i am able to boot and load their loader. box goes to http mode where i can select an image to flash (says serial mode on the front which is different!)
      then i load an image. it flashes through http says it worked, but when i reboot i get the blinking logo again. tried over installing a couple of SSLs (62 69 70) but no change.
      I feel i am close but not quite there yet. I am a bit confused on the image v SSL configs - how do i know what to try.
      any help getting this box back to life would be greatly appreciated.
      cheers
