Multirooming
  • stigmata1823
    • May 2011
    • 220
    Multirooming
    looking to have my dm800hd pvr in the livingroom and send the picture to 3 tvs upstairs and be able to change the channel upstairs as well, also have a dm500s that i want to do this with also cheers for any help guys
  • markshore
    • Oct 2010
    • 120
    If you have an iphone an app called dreamOn works great works over wifi and 3g.
    Regards
    Mark
    • stigmata1823
      • May 2011
      • 220
      looking to wire dm upstairs to 3 tvs bud cheers
      • micflair
        • 275
        Its not going to work like that mate, do you want to watch different channels upstairs to what is being watched downstairs? Or the same channel?
        If its the same channel then you will just have to get some mega long cables mate, and some form of `magic eye'.
        If its different channels then you are going to need 3 new boxes, and obviously a quad LNB for your satellite hook up.
        • stigmata1823
          • May 2011
          • 220
          just looking for same channels bud but just be able to change the channel if im upstairs
          • stew86
            • Nov 2010
            • 236
            try this website or try look around for cheaper ones
            NEW 5.8GHz Wireless TV Audio Video Sender & 3x Receiver | eBay UK
            • stigmata1823
              • May 2011
              • 220
              looking to do with wires buddy as heard wireless aint that good and rather do it right the first way cheers
              • stew86
                • Nov 2010
                • 236
                the 5.8GHz receiver are very good better tha n the 2.4 ones its says in the description on the website
                This video sender has a directional dome antenna allowing you to pinpoint the signal for the absolute minimum interference
                • stigmata1823
                  • May 2011
                  • 220
                  bit expensive for me buddy wiring is cheaper option at the moment, have you any ideas on wiring? thanks
                  • alom5
                    • 1648
                    using homeplugs would be the best option mate. very simple. and definately worth it. speciallly if you got 2 boxes, may as well make use of them both and can watch different channels.
                    • stigmata1823
                      • May 2011
                      • 220
                      keeping the dm800hd in my house bud the dm500s is going to my dads, so looking at wiring the dm800hd to 3 tv`s upstairs and be able to change channel upstairs but obviously it will be the same channel on all tvs
                      • davvo
                        • Apr 2009
                        • 666
                        scart to phono adpaters (with in out switch)
                        phono splitters
                        phono cables
                        • stigmata1823
                          • May 2011
                          • 220
                          could you give me a break down of what i need and where the cables plug into don't want to get this wrong cheers for all the help
                          • davvo
                            • Apr 2009
                            • 666
                            3 scart to phono adpaters 1 for dm and 1 for each tv
                            with in out switch ?1 each from amazon
                            2 Female phono splitter 89p each from amazon
                            3 phono cables (what ever lengths you need)
                            that will feed 2 tvs tv 1 and tv 2
                            TV3
                            for the 3rd tv you will have to use a vcr via tv 2 and split back to tv 3 with coax cable
                            or another 2 scart to phono adpaters and 1 phono cable
                            or piggy back the phono splitters with 2 more phono splitters
                            giving you 3 splits for audio and 3 splits for video
                            all you need to do now is find/buy the stuff and do it
                            scart to phono adpater yellow socket is for video
                            phono cable
                            • stigmata1823
                              • May 2011
                              • 220
                              thats spot on buddy thanks for taking the time to reply to me and to post the pics up its appreciated thanks
