how do l setup my motor dish on GEMINI
  • goose68
    • Aug 2010
    • 57
    #31
    Originally posted by smirnoff_rules
    sound m8 so that should be ok with my sim and bootloader . just load straight on this dreamup and lm away
    NO NOT DREAMUP!!!!! that takes ages, flash the image via your web browser.
    Power box off at mains (Not just stand by)
    Hold the front power button in and keep holding in
    Turn on power at mains, while still pushing in front power button, till display says stop the n ip adress shows on display
    Then open a web browser, then type in dm's ip address,
    Then select bottom option, flash new firmware,
    then you scroll to where you have it saved, then upload it restart,
    Takes about two minutes, it look's like a lot of work, but honestly it's simple to do.
    The ssl is allready in the image so you just need to flash that image on it's own.
    • westkill
      • 2378
      #32
      look here
      • goose68
        • Aug 2010
        • 57
        #33
        Yeah i think that explains it a bit better than i do.
        I have heard of people having trouble flashing the image if using firefox 4, so if you have that i would use an older version of firefox, or ie.
        • smirnoff_rules
          • 8603
          #34
          Originally posted by goose68
          Are you setting up for one sat like above, then you scroll to next sat, then ok again and so on for all the sat's you want saved.
          wooo uuuu got it working .. well l have 19e workin do the rest later thanx lads top work
          • andy91
            • Aug 2010
            • 3583
            #35
            Hi Smirnoff why dont use just use Simple,not Advanced and Positioner Mode its really simple with Usals and load Catseyes bouquets.
            Have a look at this post below.
            Also Dreamelite Phoenix Edition great image for this box.
            Andy.
            • smirnoff_rules
              • 8603
              #36
              will have to play around with tring when the footy starts ,, if they get it again , its was always a pig on my sat and to manually input the setting on that
              • goose68
                • Aug 2010
                • 57
                #37
                That good mate, glad your getting it sorted out.
                • andy91
                  • Aug 2010
                  • 3583
                  #38
                  Also well done on in reaching over 6000 posts
                  Andy.
                  • Adam_UK
                    • 464
                    #39
                    Free przitaly images Download (Only for NEWB DM800 SIM2)--UNOFFICIAL DREAM ELITE V.133DV3 PHOENIX EDITION
                    Andy.
                    I spent ages trying to get my 4 lnbs set on Gemeni and found changing from advanced to simple fixed and got it working.
