Hi there, is it possible to load mgcamd_1.35a on my db 800hd Enigma 2 Gemini Project Dreambox 800HD Pro, Alps M Tuner, BL76D if you can please tell me where i could get it and guide me how to install it, i would like to open bulsat and get the last keys and where exactly i should install them. Thanks
mgcamd-1.35a
This topic is closed.
************************************************** **Hi there, is it possible to load mgcamd_1.35a on my db 800hd Enigma 2 Gemini Project Dreambox 800HD Pro, Alps M Tuner, BL76D if you can please tell me where i could get it and guide me how to install it, i would like to open bulsat and get the last keys and where exactly i should install them. Thanks
first you need to download the mgcamd 135a and it's config
from the dreambox download server. then you load this patched version
there is a tutorial in the file, after you load this you then need to download
and load the mgcamd keys from minicat.tv
the credit for this file goes to pinkyto0oPlease Read Carefully!
original vu duo2 /vu zero/ tm-nano-se. v-box / 36v /1.2 dish, -
open the key file on your desktop then open the
dcc panel and when connected to the dreambox Press FTP
Double click 'USR' folder from the left page. and go to the keys folder
and double left click it to open then in the right hand page Double left click
on the var folder 'VAR' High light 'Keys' and use the < (arrow) button to send to the keys folder on the left widow. Do the same for the ''SCCE'' folder in the key file that needs loading thats it you are done. now the chns should open when you use your box, i have also added the keys from minicat for youPlease Read Carefully!
original vu duo2 /vu zero/ tm-nano-se. v-box / 36v /1.2 dish,Comment
Hi Benny, can I use this (pached) mgcamd 1.35a for NN2 3.2.2 too? To whach bulsat/helas 39,0E Or, is it better to load mgcam 1.37 ? If 1.37 is better, where to find it (for NN2 3.2.2) and how to install it? Thank you for your prompt help************************************************** **
NickComment
Hi, Benny, I followed your instructions as obove, but my DM 800/NN2 v. 3.2.2 got complitelly dead. No one channel shows anythink. Otherwise , when I switch back to my originally CCcam 2.2.1 , everythink is perfect. What did I wrong? Maybe this procedure is for Gemini only, and not for NewNigma2?********************************************
on the var folder 'VAR' High light 'Keys' and use the < (arrow) button to send to the keys folder on the left widow. Do the same for the ''SCCE'' folder in the key file that needs loading thats it you are done. now the chns should open when you use your box, i have also added the keys from minicat for youComment
