anyone got a readme or know how to setup a usb drive on one of this ? cheers
how do setup usb on dm800 gemini
Last edited by smirnoff_rules; 2 July, 2011, 12:57.any information provided is for educational/experimental purposes only.Tags: None -
lm not going to use a harddrive just want to mount and record to a usb stickany information provided is for educational/experimental purposes only.Comment
did that m8 no problem . its shows its there but in the recording route is only shows hhd not media / hhd so cant change that ?
says direct-access dev/sda in device managerany information provided is for educational/experimental purposes only.Comment
yea done that .. u couldn't write afew more lines
, this is going to take forever
dosnt show that option m8 ?any information provided is for educational/experimental purposes only.Comment
ok got it to work now , could only set timeshift but looks like the rest r ok on hhd/movie ? anyway its recording
but need a good epg now . anyone know if the gemini have a good one ?
cheers again ladsany information provided is for educational/experimental purposes only.Comment
that just takes me to file manager , l have looked in the add on and plug ins and thats not there ..
For Gemini users with version 5 or higher (OE1.6 VERSION) :
Copy the xmltv-importer plugin to the directory /tmp
Open a Telnet session to your dreambox, use therefor DCC or Putty or a DOSbox.
In this Telnet session type the following commands :
# cd /tmp [enter]
# ipkg install python-compression* [enter]
# ipkg install enigm* --nodeps [enter]
# mkdir /etc/epgimport [enter]
Now copy the rytec.sources.xml with FTP to the directory /etc/epgimport
You have to configure Gemini 5.0 so it is able to read the EPG files (use the remote control):
Press Blue button, then settings, epg
off
off
off
15 min (does not really matters)
off
on
epg.dat
/media/hdd
off
After these settings have been made press the green button and restart Enigma.
Now see if you can add providerlists for the import.
Known Issue***8217;s :
There are incompatibility problems if you use Gemini 4.5 or higher, keep this in mind !! Reason : Gemini is implementing epg.dat functions.
It can also happen that automatic EPG Import will not function properly after installation, although manual EPG Import works fine,the workaround is to open a telnet session to the dreambox.
Then after login with root, type behind # init 4 this will stop enigma2.
Now change in xmltv.dat the time to import 5 minutes later and change the value random to 0 (you can do this with DCC for example).
In the telnet window type # enigma2.sh
Wait untill import starts and after this is completed and change back the importtime to 4:45 and the random value to 1.
After this you choose restart enigma via menu.
Now wait untill prompt is coming back in telnet session and type behind # init 3
This will start enigma again. (now you have to wait another day to see if the automatic import works)
Sector Software, Sector ledenadministratie, Sector fitness application
looks like a right pain
Last edited by smirnoff_rules; 4 July, 2011, 19:24.any information provided is for educational/experimental purposes only.Comment
