Decent image for 800HD Pro
  • dbsatm
    • Jun 2011
    • 21
    #46
    Originally posted by bigoz
    tried again and it worked this time - now to try and get the EPG working!
    Menu --> Plugins --> TSPanel --> Addons --> Dreambox Addons --> TSPanel 3.1 (Update this first)
    Then:
    Menu --> Plugins --> TSPanel --> Addons --> Dreambox Addons --> Plugins --> Crossepg-oe1.6_0.6.2-svn-305 (or newer if available)
    Then:
    Menu --> Setup --> CrossEPG --> configure (mainly defaults but can put epg on usb or hard drive).
    Then:
    Menu --> Setup --> CrossEPG --> XMLTV Providers --> select rytec UK xmltv then download.
    There might be a step I've missed but I'm sure this is what I did to set it all up Enjoy!
    • bigoz
      • 105
      #47
      thanks i'll give it a try - can it be set up to automatically download the rytec EPG every night, or can this only be done manually as you've described here?
      Then:
      Then:
      Then:
      • bigoz
        • 105
        #48
        Followed your instructions and got the cross EPG installed OK, but the Rytec UK doesnt populate any of my channels with info? any ideas????
        • smirnoff_rules
          • 8603
          #49
          post 45 worked for me and is updating fine , 7 days yesterday checked again today and still 7 days so it updates fine
          • dbsatm
            • Jun 2011
            • 21
            #50
            That's strange it definitely did work straight away for me but maybe you need to go into the crossepg config and down near the bottom there's a convert database option so maybe it just never ran that bit? The only other thing I can think is to reboot your box then try the download again and see how it goes?
            I've had issues on other images with it not population the epg but with newnigma it just worked straight away!
            • bigoz
              • 105
              #51
              Sorted - thanks
              • smirnoff_rules
                • 8603
                #52
                Sorted - thanks
                how did u sort it ,, others will want to know m8
                • bigoz
                  • 105
                  #53
                  rebooted the box and downloaded again as suggested in the previous post
                  • darguewin
                    • Feb 2010
                    • 116
                    #54
                    after loads of messing about i found the newnigma2 out of downloads is very good image. for epg on this image i get full 7 days.
                    iv tryed about 9 images and i just like this 1, spent most of a sunday swaping images.
                    here is how i did it. i flashed my box with newnigma2 out of downloads, i had to set the av using the display on the front of box.
                    after all usual set up ie. putting on 2.2.1 cccam and tuner set up ect.
                    you have the box working you now need to download crossepg. so press blue button and select tspanel and download crossepg. then re start your box. now go to menu, steup, crossepg, configure, set storage to harddisk, turn all the other answers to yes, schedualed downlod to once a day, now set a time good for your box to do epg download. mine is set for 7.30am then press red to come out. now go to xmltv providers. pick what epg you want my epgrytec uk xmltv. now go to update rytec providers selsct and this will auto update providers, now exit out of the cross epg. now go to plugins and select crossepg downloader, this will download all epg. re start the box and you have full 7 days epg. please note this has to have harddrive of some sort for this to work. this image is for clone sim 201 make sure the image you flash is for your box. the image is in downloads at top of this page
                    every thing you need is on this site to get up and working.
                    i think the image looks really good and it stable.
                    but as the images are patched for clones please dont update the firmware, when you asked just say no or the box will stop working and will req a re flash.
                    hope this helps
                    if this helps you please press thanks button so i know who its helped
                    • rudy691
                      • Oct 2010
                      • 77
                      #55
                      thanks for the instructions mate.
                      how do i mount the usb stick in the box ? do i just plug it in ? after i plugged it in, it gave me the option to choose 'harddisk' in the epg config, but i dont know if its working or not, as i couldnt get epg to run really :/ im now having problems how to turn the subtitles off :/
                      i think i'll just start fresh and flash the box again.
                      you're mentioning this image mate ?
                      Digital Kaos - Downloads - newnigma2-exp-dm800-ssl82.rar
                      • darguewin
                        • Feb 2010
                        • 116
                        #56
                        im unsure about the usb stick as i fitted hard drive to my box. some one should be able to help you tho. yos image im using is newnigma2-exp-dm800-ssl82.rar
                        • rudy691
                          • Oct 2010
                          • 77
                          #57
                          yeah, thats the one ive got now.
                          • andy211081
                            • 575
                            #58
                            nice image...have a few issues with the skins i download they make my box crash all the time...anyone got any decent skin advice for this image
                            dreamelite pheonix v3
                            Ladies and Gentlemen, this is your captain speaking. I have the only gun on board. Welcome to Con Air.
                            • darguewin
                              • Feb 2010
                              • 116
                              #59
                              well im using newnigma2 and its perfect for epg and is stable.
                              • matricharia
                                • Jul 2011
                                thank you!
                                thank you!
