dm800 se
  • tab99_uk
    • 227
    dm800 se
    just received my dm800se to i put New Dream Elite DM800 SE Image on it works fine.
    but when i press the OK button the info bar does not show up just a red circle at the top when pressed.
    but when I'm selecting the menu and press OK it works i can select plugins i have tried 3 different remotes still the same dont know if its a problem with image or box the image says if you press ok u will get osd but i dont.
    is anyone else having same problems and what rpms are you keeping the fan speed to??
  • southpaw
    • 2233
    Maybe an option within menu . Setup. Customize. To show info bar . Select yes and then try
    • andy91
      • Aug 2010
      • 3583
      If you install the ipk file called Pauli Neutrino Keymap and select Neutrin Classic this will bring up the info bar and make the remote alot easier to use.
      If your using Dreamelite it should be in addons download manager.
      Andy.
      • tab99_uk
        • 227
        Andy.
        i cant find a vesrion for the dm800 se will the dm800 plugin work dont want it to green screen me.
        • tab99_uk
          • 227
          its already enabled m8
          • lombard
            • Aug 2008
            • 793
            where did you get it from if you dont mind me asking and price ?
            • tab99_uk
              • 227
              got mine from a lady called ruby B.C.T.(Shnezhen) Computer Company Ltd--
              email adress is [email protected]
              1pcs DM 800DH SE by DHL and paypal :250usd thats including delivery
              its 200 usd without delivery
              to it comes to about 156.00 delivered.
              • tab99_uk
                • 227
                Andy.
                ok m8 installed the plug in still no difference could their be a fault with the box or image when I'm in menu or want to select something i click OK it works but its just the info bar when i press OK just get a circle on top right of screen.
                • alom5
                  • 1648
                  if the button works otherwise, then it's gotta be in the settings...........i don't have one yet so can't tell you where.
                  maybe try a few different images......but it just gota be in the settings somewher....
                  • tab99_uk
                    • 227
                    sorted its the skin tried a diffrent skin and the problems gone.
                    • tab99_uk
                      • 227
                      had a few PMS requesting contact details for suppliers i got my box from if you look at this thread all info for sellers is in their .
                      • jasmart
                        • Apr 2010
                        • 5
                        sorry to resurrect an old thread but this comes high on the google list for "OK button does not show infobar"
                        Just another resolution - it seems the permanent timeshift plugin causes this to happen. Remove the plugin and the ok button once more functions as it should and shows the infobar.
