EPG
  • Rough Daimond
    • Apr 2011
    • 63
    EPG
    Got my DM800 up and running but not really happy about the EPG, tried the cool tv guide but not much difference really, is there an alternative out there that will give me a 7 day epg??
  • andy91
    • 3583
    Depends on what image your using Rytec SkyUK is the best and most stable,Satmate is also ok.
    Andy.
    • redone
      • 23
      crossepg is very good m8.
      Downloadable via tunisiasat
      • alom5
        • 1648
        yes, depends on which image you are running.
        all the mentioned ones are good and provide 7 days epg.
        quiet simple to install as well.
        • Rodbouy
          • Jul 2010
          • 1320
          I use Rytec also and works a treat.
          • Rough Daimond
            • Apr 2011
            • 63
            thanks chaps, what else do i need to do to enhance this little bundle of joy i have.....this is what i have got installed and if you think i am missing something or i should have or no about please let me know.
            Db800 pro hd
            250gb hdd installed and setup for pause/rewind/record ect
            a decent sub for it and a really good reception
            cross epg installed and rtyec
            bouqets sorted
            usb cooling fan for it
            anything else i should need ??
            cheers
            • rudy691
              • Oct 2010
              • 77
              i've put this image on my dm800hd
              Digital Kaos - Downloads - newnigma2-exp-dm800-ssl82.rar
              how can i get the rytec epg on this ?
              • Rough Daimond
                • Apr 2011
                • 63
                Hi Mate..i have the BH phoenix image, you need to press the blue button, red button for epg settings and then download the rytec skyuk, also you can access the TS panel>addons and downlod the crossepg.
                not sure if it will be the same method on your image??
                • rudy691
                  • Oct 2010
                  • 77
                  will give it a go, when i come back from work managed to recover my dm after no ca error today
                  • alom5
                    • 1648
                    well done.....i had same problem as well couple of days back.
                    • rudy691
                      • Oct 2010
                      • 77
                      it gave me a bit of stress that 'no ca' last night but all should be ok now
                      • alom5
                        • 1648
                        yeah.......i had to do a bit of searching to figure out what was happening.
                        got there in the end tho........phewwwwwwwwww!!
                        • rudy691
                          • Oct 2010
                          • 77
                          ok, ive downloaded cross epg and downloaded rytec. i did the configuration bit, but nothing is showing up really. is there some special way to turn this on ?
                          • darguewin
                            • Feb 2010
                            • 116
                            best image for dm800 clone post on here how i got full epg just go to end post and ul see on there.
                            hope it helps
