I have a clone DB800. How can I tell what firmware does it have? I know its Gemini but how can I tell the version so I can decide if it needs updating or no?
why do you think it may ned updating ? ,really all you should need to update are bouquets and maybe the satellite.xml file and you dont need to change image to do that .
if you give us a little more info we may be able to advise you better .
I needed to change my cccam and I couldn't find a way to do this through the blue panel. When I went to addons there was no directory Cam or Camconfig. I therefore went for a new image and installed everything that goes with it.
Went for Dream Elite Black hole found on this site.
Depending on what image your using some images like Gemini and Nabiosats Blackhole you cant download ccams no more.
Two options are to change image to something like Dreamelite Blackhole Phoenix Edition or add Mfarajs57 ts panel which you can find in the red stickies top of sat section.
If you decide to reflash make sure you select the flash with correct sim.
