genuine sly subscription card (veriety pack) nothing happens when channels selected.
  • kaisar1
    • Aug 2009
    • 462
    Hi, im having trouble getting premium channels to work on my dreambox 800 pvr bootloader 82 sim 2.01 with pheonix blackhole 133. all the channels are working in my sky hd box but for some reason when i put the card into the dreambox, black screen comes up and nothing happens.
    please can someone give me solution on how to solve this problem .TY
  • billy2
    • 1381
    have you got cams on your dreambox
    please press the little red THANKS tab
    if I helped if not press the green tab to tell me to f**Koff
    • kaisar1
      • Aug 2009
      • 462
      I don't know. How do I check? And which one should I install?
      Sent from my HTC Desire using Tapatalk
      • smoggie
        • 863
        press blue button and on that page it will tell you up the top left.you will need cam installed and the cfg file. have a look through the threads for a problem similar to yours like here http://www.digital-kaos.co.uk/forums...issing-194081/
        • lincsat
          • 1228
          You may have the card upside down, but it sounds more likely that you do not have a cam installed.
          • kaisar1
            • Aug 2009
            • 462
            Yh more likely. I just flashed the box with pheonix image
            • kaisar1
              • Aug 2009
              • 462
              got it sorted out, there was no cam installed. i followed a simple guide which i download from this site. (attached)
              regarding cfg file what is it? how do i install it? theres no sticky thread regarding cfg file.
              • satcat
                • Aug 2009
                • 14
                You,ll also need a boxkey m8,, dont use a online generator..!!! cheers satcat
                • andy91
                  • Aug 2010
                  • 3583
                  Great when you use the search button you should try more often,at this rate will call this the Kaiser section not the Sat section
                  Andy.
                  • smoggie
                    • 863
                    Andy.
                    LMAO, too true
                    • kaisar1
                      • Aug 2009
                      • 462
                      Andy.
                      y thank you, i would be honoured. admin please make it happen
                      • kaisar1
                        • Aug 2009
                        • 462
                        boxkey??????????????
                        • alom5
                          • 1648
                          Andy.
                          so so so true
                          • smoggie
                            • 863
                            here you go
                            • kaisar1
                              • Aug 2009
                              • 462
                              this dm800 is p*ssing me of!!! All day p*ssing about with it and still no luck!!!
                              HD channels are glitching/freezing e.g E4, C5 (BBC HD only one working)
                              And i aint got a clue on how to get the epg 7 day multi epg to work
                              DM800 M Tuner - 801A - using blackhole v133 image, cam 2.21 installed, rytec sky uk installed --- using sky mini dish
                              Please help
