Dreambox800hd
  • steffmak
    • 15
    Dreambox800hd
    Hi i have replaced my lnb on my dreambox800hd. I switched the box on and all i am getting is dreambox error on the small window of box. Also when i try to talk to box via my pc it does`nt connect checked all connections cables they seem okay
    Stevie
  • alom5
    • 1648
    does the box actually boot up.
    can you explain exactly whats happened. i don't think changing a lnb will make it say error on the lcd mate from boot.
    • steffmak
      • 15
      box not booting
      I have`nt used the box for a while, all i done was change the lnb powered up the box. In the small window all i can see is multimedia error and the little red light keeps flashing at the side of window. The tv shows no signal all the cables look okay ?
      Stevie
      • 00360362878
        • Mar 2010
        • 488
        Try switching off at the mains, laeve it off for a few mins, switch back on. Try a few times if needed. Sometimes helps.
        • steffmak
          • 15
          okay i wil try it tonight when i get home
          Stevie
          • steffmak
            • 15
            Hi tried various things including your suggestion still no joy can`t believe its gubbed as its not had a lot of use
            Stevie
            • smirnoff_rules
              • 8603
              wot happens when u turn off the box at the back and hold button on the front and repower box from the back . leave button pressed till u see the word
              stop and tell u if theres an ip address then
              • moosegoose
                • Jul 2011
                • 9
                if you have a dead short at lnb, like if you messed up when changing it and the inner core of the coax is touching the outer. this may cause the box to come up with error. turn off box and unscrew coax from back of box then turn on and see if it boots
                • Jo-Jo
                  • 511
                  open up and make sure the sim card is in correctly if its been banged it may have become dislodged.
                  • steffmak
                    • 15
                    Okay thanks for advice i will try tonight when i get home from work
                    • steffmak
                      • 15
                      Hi guys tried suggestions no joy as soon as power comes on the error message appears?
                      Steff
                      • Mjolinor
                        V.I.P. VIC
                        • 1093
                        Steff
                        This is also true when the LNB cable is disconnected from the back of the box?
                        • steffmak
                          • 15
                          is there any way box can be sorted or am i going to have to buy a new one ?
                          Steff
