From bootloader 76 to bootloader 82 ?
  • rhexa
    • Aug 2011
    Hi.
    How can i upload bootloader 82 to my DM800HD, it says #76 when booting but i would lke to have 82 in order to use the new images.
    Anyone that can advice me ? also where to find #82
    Cheers
    Rhexa
  • alom5
    • 1648
    flash with this
    • fluxibird
      • Aug 2011
      The DM800SE No CA Fix:
      1. Download Sunray Flasher here (for DM800SE and DM500HD with Sim 2.1)
      2. Download the Second Stage Bootloader Here Hotfile.com: One click file hosting: sim2SE_SSL82_110620.nfi It will fix the no Ca found message.
      3. Open Sunray flasher and connect via USB Mini (and use [COLOR=#6dd0f7 !important][COLOR=#6dd0f7 !important]network[/COLOR][/COLOR] mode for faster flashing) to your dm800se. Flash the .nfi SSL 82 bootloader file.
      4. Turn off box. Now hold the front standby button and power on. Open the DHCP IP in your [COLOR=#6dd0f7 !important][COLOR=#6dd0f7 !important]browser[/COLOR][/COLOR] and flash any image of your choice.
      5. IMPORTANT: Repeat Step 3. Now your done!
      Note 1. I find i cant flash an image using sunray flasher, so thats why i used the browser method.
      Note 2. If you don't get a DHCP IP, put your router IP to 192.168.0.1
      Note 3. Use Internet Explorer to flash. FF4 wont work
      • fahimjan
        • Aug 2011
        • 56
        How i can fix my DM ?
        Sometime its work fine and sometime it not works fine ?
        • pritesh12
          How does the bootloader work?
          • satt-guy
            • Nov 2010
            • 41
            but OP said DM800HD not SE!..
            • colly127
              • Nov 2010
              • 25
              BL84B is much better works a lot faster and u can use the real drives in the image.4So i would just flash a new image with bl84 b already in it
              dream elite blackhole 1.33v is a good image for it
