ok l have a 800 with blackhole on got most sats working 28 19 13 but having problems setting up 4.8 and 15.8 , can someone else's sat setting be imported into and image or ftp into box , my dm600 is fine tho ? no idea why this is playing up
inporting someone elses sat settings
Last edited by smirnoff_rules; 17 August, 2011, 17:42.any information provided is for educational/experimental purposes only.Tags: None -
go here http://satellites-xml.eu
create a file for yourself with all the sats you would want.
ftp that to the box. then set your usals settings in tuner configuration. choose the sats you want scanned and then run an automatic scan.
you should have all that you need if your sat is installed correctly. if not....you can change your usals setting by .2 increments till you get good signal.
this will sort you out mate.Comment
sat files fine m8 done it afew times l can lock on the 4.8e and save and store but when l got back to viasat pl channels the snr drops to 40% and no fta channels open tooany information provided is for educational/experimental purposes only.Comment
