error1 no ca found.... no serial port on pc :(
  • thevilla1
    • 78
    Hi folks...be gentle...i have limited knowledge!
    just flashed my moms dm800 using the web browser method over the network.. now im getting the above message...
    i need to order one of those null cable thingys... but i dont have serial connection on my laptop... is there a usb to serial null modem cable?
    is there an easy fix... shes tempted to toss it and buy a vu+!
    is there no software to flash the dm800 like flashwizard pro on the 500?
    thanks folks
  • bigoz
    • 105
    thanks folks
    you can get a usb to serial converter from Maplin
    • thevilla1
      • 78
      USB to Serial 9Pin Male Adaptor : USB Adaptors : Maplin
      one of them?
      • thevilla1
        • 78
        also.. how do i know what image to use? bootloaders etc... these 800s are more difficult than 500s!
        ive checked the sim and its 2.01 (clone)
        id like some sort of Pli Image.. anyone recommend a safe one?
        • Mjolinor
          V.I.P. VIC
          • 1093
          Yes but that is way too expensive, should be under a fiver.
          http://www.ebay.co.uk/itm/USB-2-0-9-...item1e61153ca6
          • thevilla1
            • 78
            cheers... ordered a uk one and a null cable from play.com
            so i have a few days to find out what image i can put on... how do i find out what BL i need? 72 or 75?
            • andiewill
              • Aug 2008
              • 490
              As long as the image has the correct patch you can put any bootloader / image on, just make sure it's the correct iamge for your box...
              ITgate TGM220 (swapable tuner), Dreambox 800 pro, Dreambox 500c x 2, DBox, Popbox media player.
