mgcamb
  • iiyama
    • Aug 2011
    mgcamb
    Hi there, is it possible to load mgcamd_1.35a on my dm800 clone running blackhole image
  • 00360362878
    • Mar 2010
    • 488
    Yes I'm sure it is mate, I dont use that image but if you cant get it, via the plugins in your image.
    Get the latest version of TSPanel from the stickies above,you will get it from there, ftp the file to your temp folder and install it manually via the remote.
    If for some reason it won't install from there, try and ftp the file to your root folder, then install in the same way.
    You will also need to make sure you have newcamd list in your var/keys folder, if you can't find one create your own in notepad.
    copy and paste your stuff in there and away you go.
    good luck
