Hi guys, have an issue with my dm800 using motor, im using edg nemsis 2.2 lucifer mod.. ok when i flashed with this image i then installed vhannibal settings, then i set up sat config using diseq 1.2 and picked which sats i want, all are ok accept 16e even though its set up in the sat config menu if i choose a channel on this sat it stays faded and get error message "check tuner configuration", I have heard that some images can conflict with user settings, i have used these settings for a long time an never had such issues (ran into this issue with so many images recently even with different settings)
I know that the issue could be related to the difference with position e.g one could be set for 15.8 and the other could be 16e so here is the connflict. I have tried editing the sat xml but with no joy, is there a way to tell prior to messing with the sat xml that there is a conflict of such way e.g. in my bouqets if the satellite says 16e but in my tuner config it says 15.8 would this be evidence of such an issue.
