DM800HD Tune Failed.
  • andy91
    • Aug 2010
    • 3583
    #61
    Originally posted by Watto1020
    BBC HD is 49% SNR
    advice plz?
    Just done aa pro box for a mate and on my motorised set up nearly all channels were 100% snr so sounds like your dish is off or the tuner is shagged.
    Try and tweak your long and lat that might help.
    Andy.
    • Watto1020
      • Sep 2011
      • 54
      #62
      best plan for lat/long to do a google check for them and insert into box?
      im sure SNR was higher before getting tuner replaced.. (not 100% though :-/ )
      • andy91
        • Aug 2010
        • 3583
        #63
        Sometimes if you have a signal you can changed either the long or lat to compensate for the misalignment in the dish.
        Not sure which one it is though but i know a guy who had similar results and his went from about 40 to the 90s just by tweaking one of them and rebooting,its worth a go.
        Andy.
        • Watto1020
          • Sep 2011
          • 54
          #64
          Hi andy,
          thanks for info..
          not really clued up on the dish or the box, ive tried setting long/lat in the positioner setup etc to my long/lat etc but not great..
          ive noticed my snr has gone down to about 20 now - i assume this is to do with the dish.
          but i took my box to mates to test and i get snr of 70ish, problem - its still glitchy
          now i seem to have two problems..
          thoughts please gentlemen?
          • andy91
            • Aug 2010
            • 3583
            #65
            Hi andy,
            thanks for info..
            First thing depending on where your mate lives his long and lat will differ from yours.
            If in the same area it wont make that much difference and if you didnt change it,it looks like your dish is the main problem.
            Personally i would try it on a static sky set up and see what snr you get on 28.2,this might tell you if it is a dish or box problem and the long and lat wont matter cos its a fixed dish.
            Andy.
            • Watto1020
              • Sep 2011
              • 54
              #66
              Ahh - Andy - my mate lives round corner and he is using static sky dish - achieiving the 70ish SNR..
              when i re-flashed box i had to setup tuner settings myself (this is probably my problem)
              on the TUNER should i be using simple>positioner or should i be using disqec AB or ABCD or something else?
              thanks for help
              • andy91
                • Aug 2010
                • 3583
                #67
                thanks for help
                Have it like mine in picture using usals,
                Andy.
                • Watto1020
                  • Sep 2011
                  • 54
                  #68
                  Hi Andy - mine is like that but with the Long/Lat of my house..
                  i dont have the tone ampitude though.. so could my dish be off - only getting 20-30% snr - was getting 70 a week or two ago (im quite sure)
                  also - if the box is still glitching should i get it replaced etc?
                  • andy91
                    • Aug 2010
                    • 3583
                    #69
                    Best thing you can do is get your ladder out and with a mobile phone in hand and someone at the other end skew the lnb and see if that helps with the snr.
                    Sounds like the dish is slightly offline and it only takes a knats cock to be out.
                    What i did with mine was get a permanent marker and circle round the nuts holding the motor on the bracket and move it a millimetre and have someone at the other end of the phone line telling you if the snr goes completely or gets better but mark the fixings so you have a starting point.
                    If not get asat man in to fine tune it.
                    Andy.
                    • Watto1020
                      • Sep 2011
                      • 54
                      #70
                      Thx andy
                      Even BBC hd is only 42%
                      Not had dish that long so sat guy should fix??
                      I've got my positioner at 002.891 west 053.346 north
                      • andy91
                        • Aug 2010
                        • 3583
                        #71
                        Thx andy
                        First thing i would do is grab the lnb and skew it before i go slackening any bolts but only takes millimetres for it to be out.
                        Andy.
                        • Watto1020
                          • Sep 2011
                          • 54
                          #72
                          Andy - wouldn't even know what lmb looks like ..
                          I'll call sat guy and let u know, thanks for peservering with me
                          • andy91
                            • Aug 2010
                            • 3583
                            #73
                            Sits at the end of the dish.
                            Andy.
                            • Watto1020
                              • Sep 2011
                              • 54
                              #74
                              thanks Andy - sat guy coming out this afternoon, he basically said same as you, couple of mm's all it takes.. hopefully get stuff sorted :-)
                              keep you posted
                              • Watto1020
                                • Sep 2011
                                • 54
                                #75
                                Andy - not used this dishpointer site yourself or someone mentioned in other post, im looking to see whether i should be using n / w or n/e etc
                                current details are:
                                Latitude: 53.3448?
                                Longitude: -2.8926?Satellite: 91W GALAXY 17 (G-17) | NIMIQ 1 | NIMIQ 2
                                Elevation: -7.5?
                                Azimuth (true): 268.5?
                                Azimuth (magn.): 271.3?
                                please advise what i should have in my usals / positioner settings.
                                thx
