CCcam info plugin
This topic is closed.
  • wolfspark
    • Oct 2010
    CCcam info plugin
    I'm in the process of setting up a second DM800 running Gemini 5.1.
    When I set my first one up a few months back I downloaded and installed CCcam info v1.3 from the addons panel.
    Now CCcam info is no longer available on the Gemini server is it possible to download it from elsewhere and manually install it? If so I'd appreciate any advice on how to do it.
  • satsmo
    • 6397
    Either install it manually or use the TS panel which you will find here and is highly recommended http://www.digital-kaos.co.uk/forums...ml#post1236547
    • mikk
      • 289
      Is this plugin compatible with the dm 7025?
      • satsmo
        • 6397
        Yes, it is compatible with the 7025 also.
