EPG Not Working
  • packmanuk
    • Jun 2011
    • 149
    EPG Not Working
    I had to flash my dm800hd clone. I've got the channels back but can't get the epg to work.
    I'm wondering if my hard drive isn't working or would I get an epg without one ?
    I try to add the rytec sky uk epg like I used to. It says its loaded but it does it in about 1 second so it can't be working.
    Any ideas to check my hard drive is working and how to get the epg loading ?
  • wilf
    • 1618
    can you not just try pressing record button? to see if it is working. i dont have a hdd in mine but i download satmate 7day epg ok on blackhole image.
    • packmanuk
      • Jun 2011
      • 149
      When I check the files from my pc its showing as being on the hdd. Theres nothing there though when I check on the tv.
      Anyone got any other epg I can try apart from the rytec ?
      • waj_uk
        • 175
        Try rebooting your box, mind does this periodically and when i try to download it does the same in 1 second, so i just reboot and retry from the server again
        - Sent from my iPhone using Tapatalk
        • packmanuk
          • Jun 2011
          • 149
          When I try to record it says no hdd found or hdd not initialized.
          I did try to initialize and did try to format. It seemed to work but maybe not.
          What can I do ?
          • Rodbouy
            • Jul 2010
            • 1320
            Have you mounted it?
            press blue blue then device manager then mount the hdd. The say yes to restart hdd
            • packmanuk
              • Jun 2011
              • 149
              It now says not able to initialise as the mount failed. What can I do ?
              • Rodbouy
                • Jul 2010
                • 1320
                did you do as above to mount???
                • packmanuk
                  • Jun 2011
                  • 149
                  When I do that it doesn't show the hdd when I try to mount.
                  • Rodbouy
                    • Jul 2010
                    • 1320
                    ok, try this.
                    FTP to etc/FSTAB
                    remove the # from the #/dev/sda1 line. Save then try to mount it.
                    of then try initialise it again.
                    • packmanuk
                      • Jun 2011
                      • 149
                      Where do I go to do this ?
                      • packmanuk
                        • Jun 2011
                        • 149
                        Ok I tried this and it still won't mount.
                        Is there a guide to mounting a hdd anywhere ?
                        What should the ip address be as i'm not sure its correct
