dm800hd booting so far?
  • techcs
    • Oct 2008
    • 14
    Hi All,
    Was wondering if anyone had any tips for me. I just bought a DM800HD clone for my brother and I put the Blackhole Enigma 2 image on it and it was fine for a week then it stopped booting.
    So I then reflashed with what I thought was a better image but then to get 'no ca error' So I fixed that with a patched dreamup and reflased Blackhole Enigma2 back on and it boots up to the Nabilio splash screen then it just goes black and OLED screen goes black, this is about after 10 seconds??
    Stumped now.... I can still access the STOP screen and web browse easy enough.
    Its #72 loader not sure on SIM card? Any ideas?
    I was thinking I may have corrupted the first bootloader, is that possible?
    Can you upgrade the #72 part?
    Thanks in advance...
    Col
  • kdol
    • Sep 2009
    • 45
    most images (but not all) have the bootloader included.
    Yes you can flash the bootloader in exactly the same way you do the full image - it only takes a few seconds.
    Try this ******
    • techcs
      • Oct 2008
      • 14
      Hi, Thanks for replying... so there is one listed there as an NFI file so can I do that one through the web browser at the STOP screen or is this different?
      • andy91
        • 3583
        Normally has a sticker underneath saying sim2 or something similar.
        If its sim2 put DreamElite Blackhole on it,its similar to what you had and is a great image.
        Will pm a good youtube guide.
        Free przitaly images Download (Only for NEWB DM800 SIM2)--UNOFFICIAL DREAM ELITE V.133DV3 PHOENIX EDITION
        Andy,
        • techcs
          • Oct 2008
          • 14
          Thanks.. I'm starting to think this is a hardware fault. Every image I try I get to the same point, about 15secs into boot then it either reboots or the OLED screen goes off and the red LED but the fan is still running inside??
          Thats the 5th image I tried and all the same...
          Col
          • satsmo
            • 6397
            Remove the tuner and try it again, you will still be able to access menus. I just want to see if it is the tuner/drivers that may be causing the problem. Or it may be a PSU problem.
            The bootloader is also quite old, but try as said above first.
            • techcs
              • Oct 2008
              • 14
              OK thanks for the reply. Just took the tuner out and it boots to the same time and just stops.
              I don't know how to flash the bootloader? I have the file but how does it know in the web interface that it is for the bootloader and not the complete image? I hope I make sense
              Col
              oh... I'm using the psu from my dm800hd so I guess thats ok as mine is fine.. is a sim 2.01 at least thats what it says on the card
              • satsmo
                • 6397
                Just flash the bootloader via the web interface as you would an image, make sure it is correct one for your clone.
                Last edited by satsmo; 9 September, 2011, 21:54. Reason: Removed psu remark as seen edit above.
                • techcs
                  • Oct 2008
                  • 14
                  ok, thanks for all your help. flashed the bootloader and its exactly the same.
                  using a good psu so it has to be hardware. Gonna try and send back... wish me luck
                  col
                  • andy91
                    • 3583
                    Was gonna say take out the tuner and put it back but Satsmo beat me to it.
                    Other than take the sim out i dont think theres much more you can do mate.
                    Just unlucky cos most clones seem to be ok.
                    Good luck with sending it back.
                    Andy.
                    • techcs
                      • Oct 2008
                      • 14
                      Dont suppose you know how to boot it from a usb drive? Just noticed on the web interface you can select this and it looks for the autoexec on the usb drive?
                      Col
