Why on my SE do i need to set up tuner and scan
  • garry1312
    • Oct 2010
    • 2178
    on my se once I have flashed it I send over SGT's bouquets but the channels dont work. I need to set the tuner and do a automatic scan.
    On my pro all I had to do after flash was send over bouquets and that was it no set up of tuner or no need to scan.
    Rest In Peace Michael Mcharg, A true friend and although gone never forgotten. 11-10-08.
  • andy211081
    • 575
    i dont need to scan on mine, just set uyp my tuner as you would a dm800pro
    menu>service searching>select tuner>simple config and select the eurobird 28.2e
    thats it for me then added the bouquets and rebooted
    Ladies and Gentlemen, this is your captain speaking. I have the only gun on board. Welcome to Con Air.
    • garry1312
      • Oct 2010
      • 2178
      not working for me mate what image you using. im using 4reackt but i noticed this on some other images also?
      • garry1312
        • Oct 2010
        • 2178
        also need to set the time which i never needed to do on my pro.
        • alom5
          • 1648
          i send my list across and the set up the tuner by putting in usals setting and then changing all the sats i need onto lnb1 and save. for each sat.
          then it should be there. if not a restart of gui should def sort it.
          • IAmATeaf
            • 591
            Not the same box but on my 800hd I've always had to set the tuner with every image that I've ever put on it.
            • garry1312
              • Oct 2010
              • 2178
              Issue sorted I think guys going to do some more testing today.
